Orcad Capture : PCB footprint list
jfk1948
With Orcad Capture (Demo version), how to find the PCB footprint list.
Orcad Capture requires to define footprint of each component before creating
the Netlist.
I proceed as follow :
I select a component, right click, properties Edit : how to
give some information to the PCB Footprint ?
Regards JF.
jfk1948
Joel Koltner said:
The attribute used for the PCB footprint is usually named, appropriately
enough, "PCB Footprint". What actually defines the attribute to be used
is what you fill in under the tabs on Tools->Create Netlist... -- as you
can see, "PCB Footprint" is the default, but strictly speaking you could
use a different attribute instead if you modify the appropriate fields.
My question, instead of, is :
I select a component, right click, properties Edit : how to do for obtain
the name of the "PCB Footprint", name which must be typed in the field "PCB
Footprint" ?
PS: sorry for my french translation.
