oscillator design @24GHz - which transistor
cubeagree
Hi, I want to design an oscillator working at 24GHz - output power
approx. 10dBm - but I want to use a discrete transistor (pHEMT) in a
housing which can be hand-soldered. Until now I have found only 2-3
transitors which are specified, i.e. at least s-parameters are
available @24GHz.
Does anybody can help me to choose the right transistor - any hints
are welcome. Thanks !
Rene Tschaggelar
available @24GHz.
You should select a transistor that is somewhat
faster, choose one that makes 45 GHz or more.
There is BFP520 with an Ft of 45GHz and the
BFP620 with an Ft of 65GHz, both NPN bipolars
in SOT cases though.
Tuneable ?
Rene
John Larkin
available @24GHz.
Checked the NEC phemts?
What sort of resonator did you have in mind?
John
cubeagree
John
Hi John,hi Rene
thanks for the quick answer - for the Infineon npn-transistors I
didn't find any data above 6 GHz.
The resonator will be a microstrip parallel feedback resonator - no
DRO because of difficulties in positioning in mass production and cost
issues.
The pHEMT transitors from NEC I have already checked and I think they
are quite good, I also found some from Mitsubishi and NEC, but I am
not sure whether there are any others ? So if somebody has already
designed a transistor ocillator with discrete transitors - please let
me know what kind of transistor did you use.
Thanks a lot.
Peter
cubeagree
John
Hi John,hi Rene
issues.
Thanks a lot.
Peter
colin
cubeagree said:
Hi John,hi Rene
issues.
Thanks a lot.
Peter
Not very close but I made a 1-2ghz vco with a PHEMT JFET I got from ebay,
unfortunatly havnt got the part no. to hand atm,
but the device marking is 'D' so its probably got a very long number.
It was just a delay line type feedback curtuit,
It was quite a high freq device and probably still has enough gain to
oscillate at that frequency,
although ive no way of testing at anywhere near that, sounds interesting.
Colin =^.^=
cubeagree
Colin =^.^=
Hi Colin,
this sounds interesting - I would be very glad if you can find out the
name of the transitor.
Thanks for your help.
Peter
John Larkin
Hi John,hi Rene
issues.
Thanks a lot.
Peter
I've never tried to go that fast, but it seems to me that a bipolar
with a 45 Ghz Ft only has a beta of 2 at your frequency, which doesn't
bode well for making a good oscillator. A phemt would seem a better
choice to me.
John
colin
cubeagree said:
Hi Colin,
Peter
managed to find it eventually, my disc got corupted
NE32584C
its got specs upto20ghz
even got a model upto 18ghz
posibly got >9db of gain at 24ghz
Colin =^.^=
