OT Coleman PowerMate Generator
RFI-EMI-GUY
Jim said:
bottom posting is UseNet convention.
Oh really? Please kindly show me this rule?
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
"Treason doth never prosper: what's the reason?
For if it prosper, none dare call it treason."
"Follow The Money" ;-P
Jim Yanik
Yes.
A RULE is what we use to measure distance.
A CONVENTION is where we nominate candidates.
Any more stupid questions?
Jim
No,you've proven you don't know.(also not what "context" is)
it's pointless to go further on this with you.
RFI-EMI-GUY
Jim said:
do you know the difference between "rule" and "convention?
Yes there is a Usenet RULE about Off Topic posting. Which seems to be
the "convention" on S.E.D.
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
Joerg
Tim said:
Yes, but the OP reports that he can "remagnetize" the generator and have
it produce nearly full output for a while, then watch while it fades
away. That sounds more like the field coils being fine, but the drive
circuits having failed.
Although if they're in parallel it could be one bad field coil and a
drive circuit overheating from pushing too hard -- I suspect my answer
is more likely to be correct, at least if I've got the evidence right.
While Mike is in there this would also be a good time to take a look at
the slip rings and brushes. Three years in storage could lead to a
substantial build-up of corrosion and other gunk.
amdx
Jim Yanik said:
those diodes must be in the DC outlet section,as AC generators don't need
diodes for AC output.
The 94V output is a clue to the failure;you are generating voltage under
load,but low. I'd say the field coil is not being energized sufficiently.
maybe one section of the field coils opened,perhaps a bad solder joint.
I thought maybe the diodes and cap rectified AC for the field coil. But I
haven't found a schematic and don't have a solid idea how it works.
Mike
amdx
RFI-EMI-GUY said:
Yes there is a Usenet RULE about Off Topic posting. Which seems to be the
There seems to be an unwitten rule in usenet that there will always will be
someone available to tell you when you have broken a convention.
Mike
Jim Yanik
will be
Mike
WRT top posting,when a new person views a top posted reply,they probably do
not know just what the reply is to until they scroll down and read the last
post,the one being replied to. it's also annoying.
Worse if someone "snips" the post for brevity.
threads do tend to drift OT,but it's easy enough to ignore them once that
happens,thus no big deal.
amdx
do
last post,the one being replied to. Worse if someone "snips" the post for
brevity.
Let me ask you, this thread is about 20 posts long, how many of these
did you have to scroll to the bottom to read. I'll guess almost all. I'm
sure you didn't reread every post.
A new person could read the original post and know the subject. He could
also read a top post and reply to it on top. With bottom posting, everyone
that reads the thread must scroll to the bottom. For my purposes top posting
would be great. There may be some good reason that bottom posting became the
convention, but for most people reading the thread in almost real time, it's
not the best method. With top posting
a few people may need to scroll down to catch up, but not every reader, like
bottom posting requires. Mike
amdx
Coleman powermate generator quit working 1 hr 15 min after >working
properly. (Pro-Gen 5000)
A few minutes ago I pulled the cover and found a 19 turn coil in the stator
burned (overheated, no insulation left on copper). The unit has a pcb with
8 diodes and a capacitor, a foil on the pcb has overheated and opened. The
foil goes to a 470uf 200v capacitor. The only connection to that part of the
open foil is the capacitor. Leading me to think the cap is shorted, but at
this time and temperature, the cap shows very high resistance (over 2 meg)
and deflects
the meter both ways if I charge the cap and reverse the leads. ( deflects?
I'm using a digital meter, but you know what I mean). The diodes all check
good.
I don't know if I'll attempt repair at this point. It looks like the 19
turn coil could be replaced fairly easy, it's pretty loose in the slot. The
motor was not dipped in varnish.
Later, Mike
amdx
stator burned (overheated, no insulation left on copper). The unit has a
pcb with 8 diodes and a capacitor, a foil on the pcb has overheated and
opened. The foil goes to a 470uf 200v capacitor. The only connection to
that part of the open foil is the capacitor. Leading me to think the cap
is shorted, but at this time and temperature, the cap shows very high
resistance (over 2 meg) and deflects
good.
The motor was not dipped in varnish.
Later, Mike
I pulled the stator off of the generator and upon further inspection I see
the unit was dipped, but only about 7/8 of the unit was covered with
varnish. I suspect the unvarnished part of the coil vibrated causing the
coil to short to the stator. Mike
Jim Yanik
these
I'm sure you didn't reread every post.
could also read a top post and reply to it on top. With bottom
posting, everyone that reads the thread must scroll to the bottom. For
my purposes top posting would be great. There may be some good reason
that bottom posting became the convention, but for most people reading
the thread in almost real time, it's not the best method. With top
posting a few people may need to scroll down to catch up, but not
every reader, like bottom posting requires.
Mike
it only takes a fraction of a second to scroll down.
and you can read the LAST comment before the reply.
Importantly,it keeps the thread orderly and in chronological order.
Very helpful if you decide to lokk at archived posts on the thread.
Jim Yanik
has a pcb with 8 diodes and a capacitor, a foil on the pcb has
overheated and opened. The foil goes to a 470uf 200v capacitor. The
only connection to that part of the open foil is the capacitor.
Leading me to think the cap is shorted, but at this time and
temperature, the cap shows very high resistance (over 2 meg) and
deflects the meter both ways if I charge the cap and reverse the
leads. ( deflects? I'm using a digital meter, but you know what I
mean). The diodes all check good.
19
slot. The motor was not dipped in varnish.
Later, Mike
GREAT!
I'd use my ESR meter on the cap to check it.
Can you -rewind- that 19T coil with new wire?
Jim Yanik
I see
the coil to short to the stator. Mike
Can you rewind it with new wire?
Or maybe some automotive starter rewinder could do it,if it was affordable.
amdx
Jim Yanik said:
GREAT!
Ok pulled the cap and checked it on a capacitance tester, it's BAD.
I have removed the burned coil and installed a new one. I have some motor
varnish and have brushed and dripped it into all the crevasses
as well as I can. It's in the oven as I write.
It will probably be a week or so before I can get a new capacitor.
Anyone have recommendation about ordering a replacement cap.
The original is a Nichicon CE 85 degree C LS(M) additional letters on case
0508 PET.
I have to tear this cap apart, if I shake it, it rattles. If there's
anything
unusual I'll post it.
Mike
RFI-EMI-GUY
0508 PET.
anything
Mike
Double check your diode bridge. With damage like this its surprising
there would be any "survivors".
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
JosephKK
Mike
I suspect that what you really need is the service manual, good lick
prying a copy out of their hands at this point. You may have to
threaten them with a FOIA or a lawsuit get one.
Rich Grise
You need to learn how to snip.
Good Luck!
Rich
Rich Grise
So the bottom poster crowd must be keeping the entire post just so they
can botton post, just in case a new comer will be able to read the
entire post to save bandwidth.
Nah - you just snip out the irrelevant stuff.
I used to be a fanatical top-poster, just like you top-posting apologist
trolls, but I've seen the light, and changed my ways.
I've been on both sides, and bottom-posting is better, as long as you
know how to snip properly. (maybe this is the hard part - they're not
sure exactly what part of the post they're replying to or something...)
And, of course, if there are multiple items in one post, interspersed
posting works well. BUT SNIP THE STUFF YOU'RE NOT ANSWERING!!!!!!!
Hope This Helps!
Rich
Cheers!
Rich
