Palindr☻me
- Jan 1, 1970
- 0
I am a member of a local voluntary group of mostly engineers
who design and produce and donate specialist one-off
mobility aids for the elderly and disabled. They have just
been asked about modifications to a domestic, electrical
oven - so they naturally passed it to the female electrical
engineer in the group...
Basically, what is needed is for the two shelves of the oven
to be capable of sliding out their full length, whilst
supporting the weight of what may be a large turkey, without
sagging and with nothing normally protruding beyond the
normal mechanical envelope of the oven.
I can't think of what electrical engineer has to do with
this - hence the OT - but any thoughts on solutions, no
matter how off the wall, would be welcome. There are clearly
some very bright cookies lurking around this group...
My present thought is to put wheels on the sliding trays and
run them on tracks fitted into the oven and with extension
tracks that can be clipped on by the user when the oven door
is open. By mounting the front of the permanent track on an
offset bracket, the load pushing it down and hence slightly
forward would be translated by a lever into offsetting the
rear track bracket, to move the rear of the track forward
and slightly more lower. A small spring would pull it back
to the normal position when unloaded. Thus, as the tray
slides out so that its entire weight and leverage is applied
to the front bracket, the rear bracket will pull the back of
the rail lower - thus producing a slightly uphill gradient
for the tray, which will get even more uphill the more
weight on the tray. This should be enough to counter the
bending (non-permament) of the extended rail with the
applied weight.
Any alternative thoughts, or suggestions of more appropriate
groups?
I had thought of using the ball-bearing heavy-weight drawer
slides from surplus electronic equipment racks - but somehow
don't think that they would cope with the conditions in a
cooker..They do do wonders for drawers in kitchen cupboards
though..
Many thanks,
Sue
applied weight.
groups?
though..
Many thanks,
Sue
