Bob Myers
- Jan 1, 1970
- 0
"dead inert"? a *fluoride* compound? It even sounds toxic.
Google it and see. If you don't think fluoride compounds
can be inert, I would suggest you consider Teflon....
Bob M.
John said:PV = nRT for any gas, right?
Next time, insist on Helium. Places that fill tires with
Helium instead of Nitrogen always have lots of repeat
customers, so it *must* be good!
A related question: I am about to install new speakers in
my convertible. Should I point them to the rear for better
gas mileage, or point them up for better traction? :0
DJ Delorie said:Mine have nitrogen in them. I've got a lifetime free refill plan
(part of the usual lifetime service plan, it was cheap), the tire
station makes the N2 itself from air. In my case, the water and
They claim the tire pressure is less affected by the tire temperature,
too, which may account for the 3% fuel savings in that article.
Truckers spend a LOT of money on fuel, so tiny savings are a big deal.
Good for up to about 10 atmospheres. Then you get to use something
else to compensate since the gas is no longer ideal.
http://en.wikipedia.org/wiki/Equati.../en.wikipedia.org/wiki/Van_der_Waals_equation
Michael
Things seem pretty slow in SED today, so let's talk about "Hot Air".
(Like the kind in your tires.)
Every so often I read something like this:
http://fleetowner.com/news/topstory/fleet_nitrogren_beats_air/
suggesting Nitrogen is better than air for improved mileage, lower
tire wear, reduced Global Warming, etc....
The trick is you fill your tires with Nitrogen instead of compressed
air.
Huh?! Air is 78% (or so) Nitrogen anyway.
Is there anything to this, or is this a classic signal-to-noise
problem...??
Notice too that the article does not mention any service stations so
equipped...
-mpm
John said:You could fill a tire with a high-molecular-weight gas, like a freon
or something, and it might leak less.
I used to fill my bicycle tires with propane, for that reason and to
avoid pumping. Of course, that has at least two tricky side effects.
DJ said:Except that "n" changes when you hit the dew point.
At least, that's my guess. I just don't want the water and oxygen
inside my tires any more. It sucks changing a tire in a snowstorm.
OTOH, the racing tire doesn't sit on the car for five years, rottingHowever, there is a very significant difference between
the conditions under which a racing tire operates - for
all of its hour or so (if that) of life - and those seen in
passenger-car service. Do you think that MIGHT have
something to do with the use of nitrogen in racing, such that
those same reasons wouldn't apply at all in everyday use?
Costco, and others, use only Nitrogen. No additional cost.It would be useful if Drexan's cost per nitrogen fill-up were given -
then, one could determine the break-even time, if any, for the whole
fleet, using nitrogen fill-ups vs. the cost of the additional fuel
consumed. Since this information is not given, though, I'm going by
the $100 per fill-up quoted in the Car Talk article... and, clearly,
there, it is not worth it for the individual user. $100 can buy at
least two fill-ups for my Camry (though, probably not for an SUV...)
To-Email- said:"suck out the _old_ N2..."
Bwahahahahahaha!
Must be Slowman's kid ;-)
I have that done twice a year to my wife's car. When I get back home
it'll be past time to replace the summer air with winter air[*]. If
we get an early snow storm, I'll be a dead man. :-(
.Bwahahahahahaha!
[*] The air gets changed along with the rubber; no additional
charge. ;-)
Things seem pretty slow in SED today, so let's talk about "Hot Air". (Like
http://fleetowner.com/news/topstory/fleet_nitrogren_beats_air/ suggesting
Nitrogen is better than air for improved mileage, lower tire wear, reduced
The trick is you fill your tires with Nitrogen instead of compressed air.
Huh?! Air is 78% (or so) Nitrogen anyway. Is there anything to this, or
is this a classic signal-to-noise problem...??
equipped...
equipped...
When I was in the USAF, at one point I worked on the SR-71 Blackbird
http://www.google.com/search?hl=en&q="sr-71+blackbird"
and they used dry nitrogen in its tires. But the reason, they told me,
didn't have anything to do with gas mileage, it was so that when it
lands at about 300 MPH, the tires don't explode and burn. Hot rubber
and oxygen can get a little volatile.
But, for a car, the only difference I can think of would have to do
with condensation, and just using dry air should alleviate any risk
in that area.
IOW, if somebody's making a claim like that, and expecially[SIC] if
they're trying to sell you something (like nitrogen), then they're
just blowing smoke up your ears, so to speak.
Hope This Helps!
Rich
Mine have nitrogen in them. I've got a lifetime free refill plan (part of
the usual lifetime service plan, it was cheap), ...
