Active8
- Jan 1, 1970
- 0
Habenero and stuff. Mmmm.... smack... sh*t fire and save matches.
Actually, it would be good to see the results if the codeMore comparisons. Clearly P4s SUCK!
Jim Thompson said:Win2K is the first M$ OS that I've had not a single problem with.
That's one of the reasons why I haven't gone on to XP Pro. The other
reason being that XP is basically spyware.
Plus I hate this "activation" crap that some software vendors are
going to. It amuses me how hastily Intuit (TurboTax) has retreated
from this approach, after the protest level was so high that it made
the front pages of newspapers around here.
...Jim Thompson
Jim Thompson said:[... me ...]
I assume these were all with the same OS.
I'd hope we're talking a 64b OS and software for the A64.
Otherwise the gains are truly remarkable!
JT says Win2K Pro so its a 2 bit OS
...Jim Thompson
I'll second that.
Win 2K can run fine for months on end without a reboot. XP falls apart over
time, tends to do a lot of communicating with MS, has a lot of bloat ware,
requiring higher powered computers, etc.
My next OS of choice when win 2k becomes too obsolete will likely be a Linux
variant.
On Fri, 27 Aug 2004 22:50:48 -0400, keith wrote:
Short memory?
There's a few out there that see and use Mike and a few who don't
bother with a name at all.
Take note, keith, that some call Genome DNA and vice versa.
I recall a reply to Kevin that asked where to get Super Spice.
I guess since your moniker is keith and your name is Keith, everyone
should use keith.
You ain't seen sh*tBut that's what I was taught and I'm not the only
one that'll tell you the same thing.
Sure, but DNA doesn't have a name. ;-)
keith said:I've already started down that path. It's been bumpy but I decided when
I went to Win2K three years ago that it was going the be my (first and)
last M$ OS. When I put together this Opteron system, I went with SuSE
9.1. I still have Win2K on the old system while I learn my way around.
It uses several aliases; haven't you heard of 'DNA signatures'? (;-)
LTSpice works under wine (you already knew that)
I read in sci.electronics.design that Ken Smith
Only if the wine is in the computer and not the operator.
I had never done the comparison between PSpice and LTSpice
myself, relying on the reports of others.
This noon hour I ran the latest version of LTSpice with
exactly the same setups, save-waveforms, and waveforms-to-
be-plotted. (See below.)
LTSpice came out very slightly slower.
(I should also point out that, since Mike E. last did a
comparison, PSpice added a new "Solver" to their algorithm.)
[snip]Jim,
I wasn't able to duplicate this. I find that LTspice is still
considerably faster that PSpice 10.0.0 on your circuit. But
I'm glad that since I'm distributing over 1000 times as many
copies of LTspice as Cadence is of PSpice, it's nice they still
take notice and try to catch up as they've done with other
performance improvements and features first introduced to the
industry by LTspice.
I didn't run PSPice on a P4 since my copy is
installed on the AMD Ath64.
On my 3GHz P4 LTSpice=180sec and you got 164sec.'
On the Athlon, LTSPice=104sec, PSpice=97sec.
[snip]My (older) 3GHz P4/LTspice combination beats your
Athlon/PSpice10.0.0i with a time under
90seconds using this executable:
http://ltspice.linear.com/software/P4scad3.exe
I am going to rudely make a suggestion and answer your question to Mike:[snip][snip]My (older) 3GHz P4/LTspice combination beats your
So why isn't P4scad3.exe part of your distribution?
When doing software, trying to maintain/test two versions
of the code can significantly increase the effort. The
effort would definitely not be twice as big, but it
certainly would cost more time for testing.
PS: I'd like to see a normally available P4 version,
but I understand numerous reasons why not -- even if
the reasons is that Mike chooses not to.
