output impedance of common source amplifier
tempus fugit
Hi;
How do I determine the output impedance of a common source (or other JFET)
amplifier? I know that it is roughly 1/gms, but how do you deal with the
units? E.g., if a certain JFET has a gms of 5000 uS, the output Z would be
0.0002, but surely that's not ohms is it? Or do you divide out the micro and
get an answer of 200 ohms?
F
Fred_Bartoli
Tim Wescott said:
Yes, you divide out the micro. 1 S = 1/(1 ohm), 1 micro = 10^-6; just
substitute that into the "5000 uS" expression, and solve.
Note that the forward transconductance changes with bias current; make
sure you're using the right figure, and don't forget to account for
device variation.
But the output impedance of a common *source* amplifier isn't 1/gm. That one
is the output impedance of a common drain stage.
For a common source stage you use 1/go
Also note that parameters depend on the bias conditions and that those given
in datasheets and suffixed by a 's', like gfs, gos, are at VGS=0 bias
conditions.
And for a R loaded common source stage the output impedance is often
dominated by the load resistor value.
tempus fugit
conditions.
Thanks Fred.
My mistake - I meant common drain; I was thinking source follower.
