over unity is here
ashtweth
Sep 8, 2004
14
Ashweth,
What do you mean suggestions, where to start or choice of material or what?
Kumaran,
I like the idea of using a harddrive, good bearings, good balance and easy to get. The core for the coils is a bolt, this is steel and not optimal for a magnetic core. Try to get
kumaran
May 29, 2004
51
Simple test on OverUnity got it from forum.
Hi all,
This is a very simple O/U circuit that is simply designed to show
anyone that O/U can be done as it a reality. Loads of people have
done this already, but it blew my mind and I thought I'd bring it to
anyone who hasn't see it already. Heres my replication:
Get:
1) one 10v 100uf cap and one 63v 100uf cap.
2) a low voltage LED(like on circuit boards)
3) a fully charged 9v ni-cad battery
4) a digi-volt meter
OK. Ground both caps to zero charge. Then touch 10v cap to 9v battery
to get a charge in it. Take a very quick reading on 10v cap with
digimeter and write it down.
Then connect 10v cap to 63v cap in series.( + - + -) so that there
are two legs remaining one from each cap. Secure these caps down and
complete the circuit by touching the LED onto both legs.
The LED will flash VERY briefly as the circuit is completed. Thats
it!!! Put LED down. Now take readings of both 10v cap and 63v and
write down. Now heres the good bit. Heres the result of my first test.
10v cap at 8.43v before comepleting circuit.
10v cap at 6.49v after
63v cap at 2.52v after. End result = 6.49v + 2.52v = 9.01v!
You have lit the LED and transfered charge into the larger cap, but
you havent lost any charge in the process. YOU HAVE GAINED CHARGE!
Here's my 2nd and 3rd results, I did the same test 10 times in all.
Each time ground the caps and starting from the beggining.
2nd.
10v cap at 8.67v before.
10v cap at 6.92v after
63v cap at 3.36v after. End result = 6.92v + 3.36v = 10.28v
3rd.
10v cap at 8.70v before
10v cap at 6.67v after
63v cap at 3.76v after. End result = 6.67 + 3.76 = 10.43v.!!!
Whats happening. Simply when the LED flashes a tiny magnetic field is
produced which opens a field to ZPE(or radiant current). For this
brief milisecond this field flows through the LED and into the larger
cap until LED turns off.
There is no other explination on how more total charge can be
obtained AFTER doing electrical work in a circuit. O/U and ZPE in
there simplest form.
Anyway, i said it would be simple, but it does work and at least it
works!!!
Bill.
surajbarkale
Aug 5, 2004
256
Have you measured the voltage accross capacitors after connecting them in series?
The charge equation for the capacitor is -
Q = C*V
When you connect two capacitors of same value (100uF in your case) in series, resulting circuit will have half the capacitance (50uF). So the voltage across the circuit will be doubled to mentain the charge. Similarly voltage will halve if you connect two capacitors in parallel.
This won't happen if both of them are charged.
BTW what is the full form of ZPE?
ante1
Jan 24, 2004
4,138
Bill,
The core of an old transformer contains sheet metal pieces in
kumaran
May 29, 2004
51
Ante,
I couldn't get the size I wanted. I took few ballast from old florecent light. Dismantle the ballast I got "C" and "T" shape soft iron. When to few electrical shop and ask them if they have any old transformer to throw away, they replied no (not friendly).
By the way, yesterday I discovered some strange effect to my Adams Motor during testing. Will explain deeper in Adams Motor Project section. Also will post the circuit I used to get this effect. Hope you could assist me to explain the strange effect.
kumaran
May 29, 2004
51
Ante,
Hope I could find some. By the way go to "Adams Motor Project" and read some newest discoveries I add.
ashtweth
Sep 8, 2004
14
hi guys have been busy tying t find engineers for my grvity wheel i was given a free contingent of as well as the RV
now the pdf has been updated and added too surjai , ante kumeran and all, check it out, they are just about to add a berdini pulse motor in there as well, im refering to the original pdf link at the start of this thread.
and yes ante, we have some diagrams and shcmetics for you in there this time ;D
