Hi everyone!
The attached file is a picture of an mSATA to PATA converter that I bought from eBay. It is used for example to put mSATA SSD devices in older laptops that utilises PATA interface and not SATA. The converter is built around the chip JM20330 and uses a 3.3V voltage regulator SA1084D-3.3 (datasheet: http://www.alldatasheet.com/datasheet-pdf/pdf/301356/SILAN/SA1084.html)
mSATA devices works with 3.3V while PATA with 5V. For that reason, the converter contains a 3.3V voltage regulator.
When I used this converter both in combination of my USB-IDE converter and inside my laptop, the following becomes very hot:
-the mSATA SSD device
-The converter board (mainly the regulator)
-the host system (either the laptop or the USB-IDE converter)
I'm afraid if I use it for a long time, that I destroy my laptop.
I have looked in the regulator datasheet, and they suggest using two 100uF bipolar capacitors (page number 1) one for the input and the other for the input. Looking at the converter I only see surface mounted (ceramic?) capacitors with two different sizes, and it is obvious that these are non-bipolar.
Please look at the converter and try to find/guess the reason for overheating. Could it be a bad choise of capacitors?
Sorry I do currently not have a working oscilloscope for the moment; it would otherwise have been a good help to see if the voltage is stable or not.
I appreasiate any help or suggestion
Helpful resources:
44 pin IDE pinouts: http://pinoutsguide.com/HD/Ata44Internal_pinout.shtml
44 pin IDE numbering: http://www.unitechelectronics.com/44IDEHARDDRIVE.gif
mSATA pinouts (page 8 for table, page 19 for numbering): http://www.google.com/url?sa=t&rct=...naaDXCLzFH6vhdl68IBe3lA&bvm=bv.51495398,d.bGE
Helpful resources:
