Overlay designations & miscellanea
N
N_Cook
I thought I'd messed up the USB lead of my HP 1020 laserjet , measuring
voltages etc, trying to learn about USB function. Turned out I must have
strained a USB A to B adaptor and nothing wrong with the printer. Is one
rule of thumb (for a suspect USB connection) that a maximum USB insertion
force of 250 gram is too low and above 450 gram is generally good ? ( I
later went around a number of leads /connectors, adaptors with the kitchen
scales).
Anyway inside the printer there were 6 unmarked 2 land SMD lumps marked on
the overlay as E1 to E6 , is E a designation for fuse?, all were 0 ohms
across. There were 2 unmarked green 2 land lumps on the USB lines marked VR
on the overlay, bidirectional transient suppressors ?
and 2 SMD contacting the USB lines marked CR, presumably rectifiers, but can
anyone identify with more certainty
4 land device marked topmark D132
found on topcode listings
D13 AZZ23C8V2 Diode SOT23 dual zener 8.2V 0.3W, 3 pin
related?
2 land device marked WU1
found
WU BZX284-B4V3 Phi I SOD110 0.4W zener 4.3V E24 ±2%, 2 pin
related ?
Generally do truncated 3 and 4 character topcodes have any relation to the
full code ?
F
Franc Zabkar
across.
USB ports have short circuit current protection. I believe some may
implement this via polyswitches, or some similar device, eg PTC
resistor (?). Are these devices in series with the supply pins?
CM1213 1, 2, 4, 6 and 8-Channel Low Capacitance ESD Protection Arrays
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-7/DSA-127548.pdf
Yours would be the CM1213-02Sx 2-channel array (D132 marking code). I
suspect that it would be providing ESD protection on each of the D+
and D- pins.
FWIW, this forum thread ...
http://www.monitorlab.ru/forum/viewtopic.php?p=45687&sid=52fb70466ab2db337cd6b8d9e43e15d4
.... suggests that, in a HP 1020, the WU1 part may be a ...
PESD5V2S2UT Phi A SOT23 Uni-directional ESD Protection 5.2V:
http://www.nxp.com/documents/data_sheet/PESDXS2UT_SERIES.pdf
However it is a 3-pin device.
full code ?
In the D132 case, it appears to be true.
13 -> 1213
2 -> -02
- Franc Zabkar
N
N_Cook
and D- pins.
6b8d9e43e15d4
13 -> 1213
2 -> -02
- Franc Zabkar
Thanks for that and more generally I've added
"part marking"
to "top code" "topcode" "top mark" "topmark" as synonym adjunct keywords
for SMD device coding via Google,
are there any other suggestions for more synonyms that appear in datasheets?
My sloppy typing , the WU1 is in fact 3 land
N
N_Cook
Michael A. Terrell said:
'E' is often used to indicate a connection off the board. They are
probably there for automated testing in a 'Bed of Nails' (AKA: Pogo
Pins) test fixture during the manufacturing process. More and more
manufacturing is moving to this method where boards are handled by
machines from the time the blanks are loaded into a pick & place
machine, till they are ready to be installed in a product.
No. They match the component's location on the schematics and B.O.M.
The "E" were not all the same physical size, one was quite large. Did not
try a probe on the central material but matt black , ie non metalic. If they
were in fact inductors what subclass ?, there were other items marked "L"
for inductors on the same board
N
N_Cook
and D- pins.
6b8d9e43e15d4
13 -> 1213
2 -> -02
- Franc Zabkar
I wonder how we can pick up this wildcard structure as in the Philips/XNP
datasheet
in a Google search
MARKING
TYPE NUMBER / MARKING CODE
PESD3V3S2UT / *U9
PESD5V2S2UT / *U1
PESD12VS2UT / *U2
PESD15VS2UT / *U3
PESD24VS2UT / *U4
Note
* = p : made in Hong Kong.
* = t : made in Malaysia.
* = W : made in China.
N
N_Cook
So my proper Googling for D132 ,in this case, should be of form
"D132" AND "datasheet" "part marking" OR "top code" OR "topcode" OR "top
mark" OR "topmark" OR "marking"
in the searchbox
F
Franc Zabkar
in the searchbox
IMHO, adding "filetype:pdf" in place of "datasheet" would be better:
Try this:
http://www.google.com/search?q=diode+D132+marking+filetype:pdf
BTW, I have no answer to your question regarding wildcards. It appears
that Google parses the asterisk instead of searching for it.
- Franc Zabkar
N
N_Cook
Try this:
- Franc Zabkar
I've previously tried and failed, to find a searchengine that does not
discard punctuation characters
Limiting to pdf search would fail to pick up usenet type side references
