PAL's and GAL's
Hi ppl,
I need to program sevetal PAL's and GAL's in an educational enviroment.
I will be using a hobbyist programmer to do the programming as i do not
need any large volumes.
What software is available to enter the logic equations and compile to
the fuse file? Does any schematic entry software exist which one can
enter the schemtic and compule to the fuse map?
Any sort of help on PAL's and GAL's would be greatly appeciated.
Joseph Zammit
Malta
Joel Kolstad
I suggest you visit www.latticesemi.com. They're one of the few programmable
logic vendors around who still makes GALs (aka "SPLDs," for "simple
programmable logic devices"); most other vendors (Altera, Xilinx, etc.) start
out with CPLDs (complex PLDs), which are just larger & fancier. All the PLD
vendors have a free version of their software which will work with their
smaller devices (and "smaller" is still millions of gates!)
Some of the software may still support schematic entry, but truth be told,
you're largely much wasting your time using it. PLD design these days is done
using hardware description languages such as Verilog and VHDL; your time is
much better spent learning them. (Somewhat ironically, though, most design
tools now support a graphical means of assigning schematic symbols to HDL
code, and the tool they generates the code that merely connects signals
between the various bits of code!)
I'd suggest you do a little Googling for "programmable logic tutorial" or
similar. Get a demo board with a CPLD on it and play around; many demo boards
are <$50 and you can re-program the CPLD to your heart's content using, e.g.,
a PC's parallel port connection.
Joseph Zammit
Malta
Hmm... Malta, huh? OK, getting a demo board might be a little harder. I'd
volunteer to send you one I had (it contained a Xilinx 9572, I believe), but
unfortunately I tossed it out years ago. If you ask nicely there's a good
chance someone around here will have one they're willing to part with, though.
BTW, another good newsgroup for these kinds of queries is comp.arch.fpga
(which is what CPLDs turn into when they lose their AND-OR array fixation and
turn into a sea of a bazillion little look-up tables).
---Joel Kolstad
Paul Burke
What level education is it (school or university)? If the latter, I'd
take the plunge and go straight for one of the free HDL development
systems. Perhaps for beginners, Verilog would be easier than VHDL which
is quirky to say the least. And there are loads of examples available on
opencores.org. For the device, perhaps Xilinx Coolrunner, which are a
bit small at the affordable level.
One disadvantage of this route is that the tools are baroque, and it
seems that the developers don't talk to each other. Students could spend
as much time getting the tools to behave as they do learning about the
devices and logic.
If you really want the simplicity of FPGAs, something like CUPL or OPAL
could be used. They used to be free, but I doubt their availability from
manufactureres now. If you want to go down this route, mail me and I can
send you OPALjr or one of the early Lattice schematic based ones (though
licensing might be a problem for the latter). You can use GAL or PALCE
devices- the fuse map is the same.
Paul Burke
Jim Granville
Hi ppl,
You do not mention the packages, but DIP20/24 pin SPLDs are available from:
ATMEL : ATF16V8BQL, ATF22V10QCQZ, ATF750CL
http://www.atmel.com/dyn/products/param_table.asp?family_id=653&OrderBy=part_no&Direction=ASC
Software: WinCUPL, smallish in size, compiles Boolean Equations.
If you have problems programming those, the next step is
PLCC44, and the ATF1502ASL are JTAG-ISP and 5V,with
low cost JTAG cables available.
Lattice: GAL and ispGAL variants, tend to have high Icc at
5V variants.
Their lead-free coverage is thin at the SPLD end.
Software: Part of their larger FPGA offering, so it is a large
download.
Anachip PEEL series
http://www.anachip.com/eng/product/pld.php
Software : WinPLACE, smallish in size, Boolean equation entry.
Older SW : PALASM still exists in some corners of the net, but the
supported devices list is now ancient.
Schematics: Not really worth it, with 8/10/32 macrocells,
a text editor is probably the fastest entry - and you'll need
one anyway to view the report logs.
Programming: If you can find a commercial programmer, most of
those support VECTOR test of programmed PLDs.
-jg
Deefoo
5V variants.
download.
Anachip PEEL series
-jg
I recently dug out PALASM to modify a GAL and it still works fine with my
Lattice GALs (22V10D). It will only run under real DOS though. Here it is:
http://www.engr.uky.edu/~melham01/ee481/software.htm
--DF
Jim Granville
devices and logic.
manufactureres now.
CUPL is still available, for free, as
Atmel WinCUPL
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=2759
which also includes the command line versions.
CUPL is ideally suited to the GAL/PAL level the OP mentioned -
where you code at the macrocell level.
I'd forgotten about OPALjr :)
-jg
Didi
Back in 1988/9 it was CUPL which made me write my first logic
compiler (not available for windows etc.). It cost me a day to figure
out why my 16V8 would not work until I discovered CUPL was not
taking into account the output polarity of the feedback signals (did
it right only as long as they were active high...). Fortunately,
those were the days when the JTAG fusemap was listed in the
datasheets so I could see what was going wrong and move
forward.
They may have fixed that since - I never touched it again afterwards.
Perhaps still usable as a teaching tool, having access to the lower
level data may be a great advantage in that respect. And well, if
someone has to discover some bug yet again while learning, this
will actually be advantageous, too....
Dimiter
Hi
Thanks for all the information. The only interest is more academic as i
want to use them for demonsration purposes since i teach a vocational
engineering course i do not only need to explain the use but even to
show these devices working. I cant use VHDL or Verilog because the
level is pitched too high for my students.
The reason wanting schematic entry is for my students to visualize what
is happening rather then the luxury of schematic entry for itself.
Joseph
Jim said:
[email protected] wrote:
Anachip PEEL series
I used that for years. The PA7024 was a drop-in replacment for the
22V10 work-horse, but with enough buried cells and extra routing to be
a lot more flexible. On at least one occasion I was able to rescue a
board where the designer had failed to tolerance the timing inside
their 22V10 by dropping in a PA7024 replacement and using most of the
extra cells as delay elements.
The PA7024 isn't exactly up to realising "system on a chip"
applications but you can do a surprising amount of stuff with the logic
it gives you.
These days, I'd look for programmalbe logic parts that support
in-system programming (ISP). I really like the Coolrunner parts
(originally Philips, now Xilinx) but most places where I've worked have
gone for Lattice parts for their low end programmable logic.
Jim Granville
Hi
Most of the tools can create a series of TXT files, that show the
morphing that takes place, and you can always draw covering drawings.
CUPL outputs a .DOC file, that shows the final equations, and some
intermediate ones that show the pre-parser and macro expansion results.
If you use the smaller CPLDs that also use a fitter, that also creates
a TXT report file, that shows how the logic finally mapped to the
silicon.
As a tiny example:
~~~~~~~~~~~~~~~~ CUPL .PLD source ~~~~~~~~~~~~~~~~~~~~~~
This is the Table, or simple ROM syntax - this is a 7 segment display.
TABLE GCtr => [D4A,D4B,D4C,D4D,D4E,D4F,D4G] {
Ca_ => Dri0; /* 0 */
Cb_ => Dri1; /* 1 */
Cc_ => Dri2; /* 2 */
Cd_ => Dri3; /* 3 */
Ce_ => Dri4; /* 4 */
Cf_ => Dri5; /* 5 */
Cg_ => Dri6; /* 6 */
Ch_ => Dri7; /* 7 */
~~~~~~~~~~~~~~~~ CUPL .DOC report ~~~~~~~~~~~~~~~~~~~~~~
D4A => !GCtr0 & GCtr1 & GCtr2
# GCtr0 & !GCtr1 & !GCtr2
D4B => GCtr0 & GCtr2
D4C => GCtr0 & GCtr1 & !GCtr2
D4D => !GCtr0 & GCtr2
D4E => !GCtr0 & !GCtr1 & GCtr2
# !GCtr0 & GCtr1
# GCtr0 & GCtr1 & GCtr2
D4F => !GCtr0 & !GCtr1 & GCtr2
# GCtr0 & !GCtr2
# !GCtr0 & GCtr1 & !GCtr2
D4G => !GCtr1
~~~~~~~~~~~~~~~~ Atmel Fitter .FIT report ~~~~~~~~~~~~~~~~~~~~~~
Same as above, but note the D4E has optimized by flipping the logic.
D4A = ((!GCtr0.Q & GCtr1.Q & GCtr2.Q)
# (GCtr0.Q & !GCtr1.Q & !GCtr2.Q));
D4B = (GCtr0.Q & GCtr2.Q);
D4C = (GCtr0.Q & GCtr1.Q & !GCtr2.Q);
D4D = ((GCtr0.Q & !GCtr2.Q & !GCtr1.Q)
# (!GCtr0.Q & GCtr2.Q));
!D4E = ((GCtr0.Q & GCtr1.Q & !GCtr2.Q)
# (!GCtr0.Q & !GCtr1.Q & !GCtr2.Q)
# (GCtr0.Q & !GCtr1.Q & GCtr2.Q));
D4F = ((!GCtr2.Q & GCtr1.Q)
# (!GCtr0.Q & GCtr2.Q & !GCtr1.Q)
# (GCtr0.Q & !GCtr2.Q));
D4G = !GCtr1.Q;
Paul Burke
want to use them for demonsration purposes...
Well done for introducing your students to this. Far better than the
sterile "implement the following requirements using 2 input NAND gates"
that is still all too common.
How about using one of the equation input packages, but giving the
students the task of producing the equations from the schematic?
Paul Burke
John Larkin
Hi ppl,
Joseph Zammit
Malta
The ICT Place software is (I think) free
http://www.ictpld.com/ftp/an7.pdf
but you will need a programmer of some sort.
I'm currently doing a PEEL 22CV10 design (blast from the past! There's
nothing like having 10 macrocells to make you really reduce a design)
and I'm using the older Dos-based APEEL software ("if you have a
system with two floppy disks...") which is just simple PALASYM/ABEL
syntax text entry of logic equations.
There's probably some copies of PALASYM floating around (I must have
one somewhere in the archives, I guess) for programming the genuine
oldies, the PAL16L8's and such.
John
Joel Kolstad
I have a hard time believing that your students can be smart enough to
correctly implement designs using schematic capture but not using Verilog or
VHDL. Not to mention what's already been said about industry using HDLs, so
there's questionable benefit to spending time teaching people obsolete
technology.
Unless you restrict your students to only using AND gates & OR gates,
flip-flops and perhaps an inverter on the input & output, this isn't going to
happen. All the old schematic packages already had most sophisticated
functions such as counters, shift registers, etc. built up for you to use (in
fact, some tools had complete libraries of almost all the 74xx logic ICs!).
Some tools would let you "drill down" and see the "primitive" logic elements
used to implement the functions, though.
---Joel
Jonathan Kirwan
<snip>
<snip>
I've looked over the responses and do not yet see a direct answer to
the question of allowing a schematic entry of logic leading to a fuse
map output, with a free tool.
I would guess that if you could find a package that supports schematic
entry (such as perhaps Altium Designer) and also supports GALs and
PALs (don't know about Altium on this score), that you'd get there.
But that's _very_ expensive to consider. What else might there be?
Seems simple enough to do after the schematic entry graphical part of
it is done -- and that itself can be kept relatively simple.
An idea -- not sure if it would help. But it would be possible to use
Linear Tech's LTSpice (SWCADIII) to do the schematic entry part of the
job. It's free to anyone. It isn't difficult to create the symbols
that would be used for teaching and the schematic is saved in ASCII
form. I've already written the software to parse that ASCII source
into an internal form that may be usable for generating the logic
equations which could then be input to CUPL, I suppose. Would this
fit the need?
Jon
samiam
I have got a copy of CUPL (4.x? I think) I can send you if you are
writing logic equations for 16x8 and 22v10 and such
Jim Granville
Another alternative is to use this :
http://www.tech-chat.de/download.html
That's a very nice piece of SW, by Andreas Weber, that allows
ASCII type schematics to paste into any source file.
So if we have a block that benefits from a drawing, we
use this, and paste it into the source.
Sure, it is not SCH -> 'PLD opcodes', but it is SCH
augmenting PLD source.
Altium have CUPL as one of their flows.
fit the need?
ISTR cupl had a package called Liaison (?), and it did this SCH-EQN
step [ mostly..:) ] - you need a special library suite, so the symbols
can map onto PLD structures.
We tried this, years ago now, and yes, it can be made to work.
The problems we found are, the features you loose in a SCH flow.
** There are no conditional defines in a SCH package
** Adding notes on "this workes better than that", is cumbersome
** Paste of SIM and FIT output into the source, is also cumbersome
** CUPL has multiple flows, this only works on BOOLEAN EQN Entry
** TABLE form of code is not accessible
** SEQUENCE {} State engine code is also not accessible
** Creating of simulation files is not supported.
** Waveform style comments ?
** Editing is quite slow
** CUPL allows control of what collapses, and what does not.
** CUPL can export Fitter control, via PROPERTY statements.
Not sure how a SCH flow would manage those - attributes (more work) ?
Whilst with a good programmer's text editor ( we avoid CUPLs default
'vanilla' editor ), all of the above is very simple.
-jg
N
Nico Coesel
Look for Palasm.
Its good to use both schematics and VHDL in an FPGA design. Schematics
show how the design structured and you can include small timing
diagrams. In VHDL/Verilog code it is easier to describe complex logic
functions (like a state machine) which are total spaghetti in a
schematic.
If you write everyting in VHDL/Verilog you'll need to make a separate
picture which shows how everything is connected if you want someone to
be able to alter your design.
Joel Kolstad
Hi Nico,
Yes, I agree with you. The point I was trying to make -- pretty poorly given
how I worded it -- was that these days a schematic symbol such as an AND gate
gets mapped to some VHDL or Verilog code, which then gets synthesized down to
primitives & placed/routed. Whereas historically the AND gate was, itself, a
primitive.
Jonathan Kirwan
Actually, I think you missed understanding me. Maybe not, but the
above looks to me like that. Probably my fault.
The only reason I mentioned "ASCII" was technical, not visual. I am
thinking about the possibility of using LTSpice as a free and
graphical and supported schematic capture tool. No ASCII here. I
mean, an easy to use tool for laying out the logic and editing it. The
ASCII part is about the save files -- which aren't supposed to be read
by humans even though they are ASCII. I was proposing the idea of
reading those save files and automatically generating the input source
to CUPL from that.
None of this has anything at all to do with Weber's tool (or my tool
which supplements his by using LTSpice for a similar purpose.)
The point is that they aren't free... or cheap.
fit the need?
Which is what I'm imagining LTSpice for, if I gather you correctly.
Now to the interesting part.
Okay, this *could* be handled with specially annotated TEXT in
LTSpice, I suppose. I'm no expert on this application space, so I'm
ignorant about how this might work well in a schematic capture
situation and I'm also ignorant about the teaching situation which may
or may not need this feature. But I don't imagine it poses a serious
problem, from my vague understanding of you.
What do you mean by the above? I just don't follow, at all.
I'm ignorant of this. Can you help me or point me somewhere? (I
suppose I can search -- and will -- but I wouldn't object to a pointer
or comment from you about it.)
I was mentioning CUPL only because I saw references. Could be PALASM
or other tool input source, as well, I imagine. Whatever is needed by
the teacher is all I'm thinking of.
Might be okay for teaching. We aren't talking about a complete tool
here, though I wouldn't be averse to suggestions about how schematic
capture could be made to work smoothly with a variety of such compiler
input source formats and features.
Same comment.
Did the teacher mention that?
And why not point out which free tools might achieve that, too? If
any. No reason why those input file formats couldn't be supported --
or is there?
Got me.
In LTSpice? I'm fine with it.
Again, I suppose I need to be smarter about CUPL. I'm not, right now.
So my ignorance allows me to see this as "no problem, yet." The
question is, can a schematic capture program like LTSpice, tethered
together with a command line tool that knows how to read the save
files and parse them correctly, be used in conjunction with other
standard tools to make a completed and useful package for teaching?
I'm still thinking so. But I'm ignorant. So I'll read with
attention.
I get you. So you are arguing hard against the use of any graphical
schematic entry method for the students. But the instructor has
already said this is desirable for his use. I'm willing to go with
that assurance.
Jon
Joel Kolstad
Jonathan Kirwan said:
So [someone else is] arguing hard against the use of any graphical
