PAL's and GAL's
Jim Granville
Jonathan said:
Actually, I think you missed understanding me. Maybe not, but the
above looks to me like that. Probably my fault.
The only reason I mentioned "ASCII" was technical, not visual. I am
thinking about the possibility of using LTSpice as a free and
graphical and supported schematic capture tool. No ASCII here. I
mean, an easy to use tool for laying out the logic and editing it. The
ASCII part is about the save files -- which aren't supposed to be read
by humans even though they are ASCII. I was proposing the idea of
reading those save files and automatically generating the input source
to CUPL from that.
None of this has anything at all to do with Weber's tool (or my tool
which supplements his by using LTSpice for a similar purpose.)
I think I understood, I merely menioned this as another alternative.
What the OP was after was
<paste>
"The reason wanting schematic entry is for my students to visualize what
is happening rather then the luxury of schematic entry for itself."
ie to me that is more a concept/visualize request, than a full tool flow.
It's his call, as to how to get that visual assist to his students.
The point is that they aren't free... or cheap.
Very True - I was just clarifying your (question) about Altium and PALs
But that's _very_ expensive to consider. What else might there be?
Seems simple enough to do after the schematic entry graphical part of
it is done -- and that itself can be kept relatively simple.
An idea -- not sure if it would help. But it would be possible to use
Linear Tech's LTSpice (SWCADIII) to do the schematic entry part of the
job. It's free to anyone. It isn't difficult to create the symbols
that would be used for teaching and the schematic is saved in ASCII
form. I've already written the software to parse that ASCII source
into an internal form that may be usable for generating the logic
equations which could then be input to CUPL, I suppose. Would this
fit the need?
ISTR cupl had a package called Liaison (?), and it did this SCH-EQN
step [ mostly..:) ] - you need a special library suite, so the symbols
can map onto PLD structures.
Which is what I'm imagining LTSpice for, if I gather you correctly.
We tried this, years ago now, and yes, it can be made to work.
The problems we found are, the features you loose in a SCH flow.
Now to the interesting part.
** There are no conditional defines in a SCH package
Okay, this *could* be handled with specially annotated TEXT in
LTSpice, I suppose. I'm no expert on this application space, so I'm
ignorant about how this might work well in a schematic capture
situation and I'm also ignorant about the teaching situation which may
or may not need this feature. But I don't imagine it poses a serious
problem, from my vague understanding of you.
Here is a CUPL conditional define :
$IFDEF TermC_Zero
CountEN = !(DivFD : 'd'000); /* terminal Count, loads when hits 0,
so Divides by NUM+1, not NUM */
$ELSE
CountEN = !(DivFD : 'd'001); /* terminal Count, loads when hits 1,
so Divides by NUM, not NUM+1 */
$ENDIF
What do you mean by the above? I just don't follow, at all.
Just ones normal source code comment, in any deisgn language.
Here is a real example, of a result comment, from a CUPL design
Fitter v1897 => 440.5Hz with 001 TC, and 76 PT,
Fitter v1897 => 440.1Hz with 000 TC, and 85 PT, -- hmmmm...
I'm ignorant of this. Can you help me or point me somewhere? (I
suppose I can search -- and will -- but I wouldn't object to a pointer
or comment from you about it.)
another example, here are SIM and FIT outputs :
This from a CUPL .SO file ( sim Output ) - can be
pasted into source, /* inside comments */
K
O O Ne
O s s ID ey
s c c ID ne wS
c F F ne cc Kt
I B B cc DD ea
N T N ButQ DD QQ yb GCtr
Revised for Version 1.0
POWER ON, Osc Check
0001: 0 L X 1111 LL LL LL LLL
0002: 1 H X 1111 LL LL LL LLL
0003: 0 L X 1111 LL LL LL LLL
State track, one click, Ba_ to Bb_
0004: C L X 1110 LL LL HL LLL
0005: C L X 1110 LL LL LH LLL
0006: C L X 1100 HL HL LH LLL
0007: C L X 1100 LL LL LH LLH
0008: C L X 1100 LL LL LH LLH
0009: C L X 1100 LL LL LH LLH
0010: C L X 1100 LL LL LH LLH
0011: C L X 1100 LL LL LH LLH
and this from a FIT file (Squashed to hopefully avoid wrap )
Device here is an ATF1502BE
MCell Pin# PinDrive DCERP FBDrive DCERP CascadeOut TotP
MC4 1 TDI INPUT -- -> IncD 5
MC5 2 -- IncD C---- -- 3
MC7 5 -- IncDQ Dg--- -- 1
MC9 7 TMS INPUT -- -> DecD 5
MC10 8 -- DecD C---- -- 3
MC13 12 But0 INPUT KeyEdgeA Dg--- -- 1
MC15 14 But1 INPUT DecDQ Dg--- -- 1
MC27 23 -- -- -> GCtr0 5
MC28 22 -- GCtr0 Dg--- -- 2
MC29 21 -- -- -> GCtr1 5
MC30 20 But3 INPUT GCtr1 Dg--- -- 2
MC31 19 -- -- -> GCtr2 5
MC32 18 But2 INPUT GCtr2 Dg--- -- 3
MC0 37 OscIN INPUT -- -- 0
Total Pts 60
I was mentioning CUPL only because I saw references. Could be PALASM
or other tool input source, as well, I imagine. Whatever is needed by
the teacher is all I'm thinking of.
Might be okay for teaching. We aren't talking about a complete tool
here, though I wouldn't be averse to suggestions about how schematic
capture could be made to work smoothly with a variety of such compiler
input source formats and features.
Same comment.
There are tools out there for Graphical State diagram entry, so
I suppose an ideal Schematic front end would include/emulate one of those ?
Did the teacher mention that?
No, but he did mention programming real devices, and if
I was teaching this, I'd certainly try and match theory with practise.
If he wants to set simple class tests, simulation is a great way
to mark them.
It also outputs TestVectors on the JED files, but in this case,
the OP's budget might not run to a Vector-Programmer.
And why not point out which free tools might achieve that, too? If
any.
CUPL is free
No reason why those input file formats couldn't be supported --
or is there?
Got me.
In LTSpice? I'm fine with it.
How does that handle BUS connections, and node names ?
The Spice I have has no BUS support (why should it?),
and it uses the spice std of node numbers.
Again, I suppose I need to be smarter about CUPL. I'm not, right now.
So my ignorance allows me to see this as "no problem, yet." The
question is, can a schematic capture program like LTSpice, tethered
together with a command line tool that knows how to read the save
files and parse them correctly, be used in conjunction with other
standard tools to make a completed and useful package for teaching?
I'm still thinking so. But I'm ignorant. So I'll read with
attention.
Yes, it can certainly be made to 'work' - I was just pointing out
what one stand's to loose, in functionality, for the cost of another
layer of complexity.
I get you. So you are arguing hard against the use of any graphical
schematic entry method for the students. But the instructor has
already said this is desirable for his use. I'm willing to go with
that assurance.
Not really - I offered above an alternative method of involving circuit
drawings - which we use here quite productively. No extra SW needed.
I also have some Spice examples here, and am working with a Spice
supplier, to encourage them to import PLD eqn infos, so they can
do mixed Analog/PLD simulations.
To clarify, with some of the design constructs we use, I have no idea
how one would draw them with any clarity in a schematic, so to me that
will always be a subset-flow.
Where I can see a strong case, is for using Spice/Schematics in the
simulation side of the design flow. - ie use your tools to their strengths.
-jg
K
Ken Smith
their 22V10 by dropping in a PA7024 replacement and using most of the
extra cells as delay elements.
The PA7024 isn't exactly up to realising "system on a chip"
applications but you can do a surprising amount of stuff with the logic
it gives you.
Unfortunately they never made a CMOS version of the PA7024s. They are
quite power hungry. This is the only real down side to the part. I
really liked the ability to use the flip-flop on the input, it let you get
a lot done in a small package.
Paul Burke
John said:
I'm currently doing a PEEL 22CV10 design
They are beautiful devices, worlds better than GALs. A rich choice of
feedback (you can configure an embedded flipflop, and use the associated
pin as an input) and the clock is fed into the product matrix. Sad that
they never really caught on, and I'm not sure that anyone else ever made
them. Though ICT did irritate me badly by changing the programming
algorithm just after the manufacturer of my programmer stopped
supporting that model.
Paul Burke
CBFalconer
Joel said:
Yes, I agree with you. The point I was trying to make -- pretty
poorly given how I worded it -- was that these days a schematic
symbol such as an AND gate gets mapped to some VHDL or Verilog
code, which then gets synthesized down to primitives &
placed/routed. Whereas historically the AND gate was, itself, a
primitive.
Only to those who didn't minimize logic in the first place. The
old fashioned way was to generate minimized logic equations from
Karnaugh maps, and then implement that with gates.
"If you want to post a followup via groups.google.com, don't use
the broken "Reply" link at the bottom of the article. Click on
"show options" at the top of the article, then click on the
"Reply" at the bottom of the article headers." - Keith Thompson
More details at: <http://cfaj.freeshell.org/google/>
Also see <http://www.safalra.com/special/googlegroupsreply/>
Jim Stewart
Another PEEL lover. I thought I was alone
in the world. Very nice devices and never
had a lick of trouble with them.
John Larkin
They're handy. Nice 5-volt logic blocks. Production can program and
label a tube of them at the programming station, and later plug them
into sockets on boards without all that JTAG nonsense.
John
Jonathan Kirwan
Elsewhere on sci.electronics.design:
The latter, logisim, allows a bus. It's also at SourceForge, so
modifications to it to support what's needed not only for simulation
of the logic but also then creating a fuse map are possible, I'd
suppose.
I have used VHDL and Verilog with some CPLD and FPGA parts and have
enjoyed that. But I haven't had to do PAL and GAL programming with
PALASM or CUPL. So my ignorance allows me to imagine that a good,
free graphical tool could be applied to good purpose in teaching.
In any case, there hasn't been enough of a response from the OP. So I
should bite my tongue, I suppose.
Jon
Jim Granville
suppose.
Interesting, I've book marked that.
The OP could use this to get the ideas across, then code in CUPL.
Seems logism is purely digital, so misses my target of mixed-simulation,
but I can see it could expand in that domain by :
a) Adding EQN output ( also needs library work ) ?
These libraries then tend to restrict the flow to specific
back ends.
b) Adding table SIM output, in JED.Vector syntax, which would
append to the JED file created by the other flow
Doing the latter would give some interesting parallel paths.
c) Add an ASCII export, so you can paste into TEXT based source ?
The above logisim looks useful for that.
Well, he now has many suggestions to follow up on. :)
My present area is pushing PLDs into mixed-signal space, and
this will be using a good graphical tool for the teaching (Spice).
I will not be (initially) pushing for this as a whole flow, for the
reasons previously mentioned, but will focus on the areas where
there are presently no tools at all.
Another drawback of Schematic Entry, is you tend to get binary
format source files, that can have lifetime dead-ends.
See some of the threads in Comp.arch.fpga on this issue....
-jg
Jonathan Kirwan
Me, too. I've only played around with it for a moment or two, but
it's reasonably easy to use. Actually, looking at both it and the
Digital Works mentioned earlier, logisim looks a lot like it was
developed afterwards to expand on the ideas of the other. Too similar
in their handling of manual input sources and led outputs.
What I liked about logisim is that there is no installation at all.
It's just an exe and it works right away. Couldn't be easier unless
it was grafted into the BIOS. ;)
Which isn't my focus (I mean, mixed signal isn't), though I'm
attracted to it. It's just that I haven't found convenience (I'm a
hobbyist) and quality in the same package -- the Cypress PSoC
mixed-signal thing didn't impress me much on the analog side so I've
just stayed traditional, with separate substrates for digital and
analog -- I think it is just still too hard for FABs to try and do it
well, monolithically.
back ends.
Good. I thought so from my limited perspective. Maybe this tool
would be a launching point for something, then...
He does!
Understood. I can see better now why you were chipping in -- because
this is something close by to what you've been considering.
Fix the holes, first. Then worry about an easy flow.
LTSpice puts out ASCII. It's not exactly human-readable, but it
transports easily through just about any software layer on the net and
can survive various translations of end-of-line and end-of-file file
system variations. I wrote a lexer/parser by hand for it in about two
days, without any documentation from Linear and just creating lots of
files for examination. So far, it's been holding up okay.
I haven't checked on the output of logisim or digital works, so I
can't speak to them.
One nice thing about this being SourceForge'd, assuming all the source
and development tools are in the open there, is that it can be kept
alive nearly forever if it continues to have some interested folks
needing it. It's not going to die just because some company decides
it's past its profitable maturity cycle.
Jon
Jim Granville
I should clarify my mixed-simulation a little.
I'm with you on the "Full analog with Digital" issues, but
where I am pushing the CPLDs is more into Oscillators (RC, one, two ,
three terminal), LC, and Crystal, Digital DACs, and Oscillator Trim
schemes, and also PLLs ( a la 4046 ) (etc).
So this is more Quasi-Analog : Nice to know what values R & C to
choose, and a 'picture is worth 1000 words' education stuff.
I do have a nice design for a Function generator, using a CPLD and
a Quad Opamp.
-jg
