Panasonic SAPM-31 Mini hifi, Tapedeck motor running all the time
Tapecaptain
Apr 11, 2022
Hi
I have a Panasonic SAPM-31 mini hifi and the tape deck motor keeps spinning all the time
If I just connect the ribbon cable to PCB That is connected to the motor, it spins continuously
If I change the input it still spins
I have put it all back together with all the belts in place and still
I can play, forward and rewind but the motor never stops when I press stop
This never used to happen so I am not sure if a transistor has failed or a diode
I will really appreciate the help from this forum
Thanks all
Here is the service manual
https://www.manualslib.com/manual/14...-Sa-Pm31p.html
kellys_eye
Jun 25, 2010
6,512
The motor is shown on page 80 (bottom). You will need to check voltages around Q1316 and Q1314 and (maybe) go backwards from there.
Tapecaptain
Apr 11, 2022
Thanks for the reply
The system works and the tape deck works but the motor is continously running until I click the off button
After reading the schematic I can see it is stated that q310 is a motor switch and q309 is a plunger switch
The plunger works fine but the motor is always running
Is it possible that q310 has become faulty
73's de Edd
Aug 21, 2015
3,730
If you check the incoming motor drive signal from uP . . .IC600 pin 43 . . . . . that output port feeds that darlington pair motor power switching transistor Q310, and the tape drive motor will start running . . . .when the TAPE function from the selector is opted upon.
Then the actual mechanical selection / engagement of play / record - - - - - -fast forward - - - - - or . . .rewind actions will result in a tape transport movement, excepting for the STOP mode.
There, any tape movements would stop, but the motor is still running. But, if you were then to switch it off of TAPE mode, the motor would THEN stop.
Synopsis . . . .
If in TAPE mode, motor runs to be ready for command of mechanical transition to play or FF or RW modes . . . .if left on stop mode motor runs . . . . if switched out of tape mode, motor stops.
Check the pin 43 voltage presence and confirm his.
Finally, you said . . .
If that means that you switched it out of TAPE mode, and found that you had NO base drive voltage coming in from pin 43 . . . . .then expect a shorted Coll-Emitter of Q310.
Erstwhile
Apr 12, 2022
47
Good answer Edd,
I recall a Pioneer tape deck (1980s era) that left the capstan(?) motor running all the time, but maybe, as you wrote, it was only when the deck was in a particular mode.
