Panasonic TV Model CT-27G12CV Help Needed
Dean Batute
Hello All.
my sister dropped her TV off to me to look at for her. Initially she
said the picture would shrink to a thin horizontal line (Loss of vertical)
but giving it a HIT on top of the set would bring it back. This happened a
few times over the last few weeks. NOW nothing! I took the back off, cleaned
it up, poked around for loose contacts, wires, etc then powered it up. R552
blew in the High voltage section. I can read Brown, Black, but the
multiplier band is charred. Any chance someone can tell me the value of this
resistor and perhaps give me some pointers as to what I should be looking
for. I'm guessing some simple touching up of the solder joints should fix it
but I'm suspicious of this blown resistor.
Thanks a bunch to any and all who can give me a hand.
Cheers....Dean.
Ricky Eck
Well, thanks going out to Wizard, he helped me with my problem on this. My
wife was doing the same thing, when the tuner wouldn't work. Well, guessing
the constant pounding, caused the Vert to burn out. First about the
Resistor. Mine was a 1 ohm (Brown, Black, Gold, Gold.). However, I would
also check the Vert IC. I found mine to have a burn hole in it, that I
first missed. But after Wizard's expertise, I was able to trace it down.
Look through these post for the one marked "Cross Ref "?" Posted 5/8/2004 by
myself" And read through the whole post, it will give you the info you need
to get started.
Hope this helps...
Rick
