Panel Heater Power Board repair
FIIIP
Feb 26, 2026
12
I have this power board that use chinese PN8024R regulator to output 12V, but instead outputting 12V it outputs like around 28v to 50V.
If anyone have any idea what could be wrong, please let me know. Here is the thread from another forum: https://forum.allaboutcircuits.com/t....208572/page-4
Thank you!
mechtronics
Aug 7, 2011
164
Yes, they were fine, but I replaced them anyway
what about all other components? capacitors? inductors? etc and how did you check them? did you physically desolder them and take them out and check them? and another thing to point out is a lot of switch mode power supplies use feedback so when a load is connected to it the output voltage stabalizes. under no load voltage will be higher than usual. under load voltage stabalizes. when you have something connected to the output use a digital multimeter to check what the voltage is when load connected to output.
bertus
3,877
Did you have a look at the datasheet?
Bertus
  • PN8024R.pdf
FIIIP
Feb 26, 2026
12
Yes, I have desoldered all components, and checked them, here is the list.
@bertus Yes,I have checked it, I am not building their rtypical usage scenario with these components to see how it will behave.
FIIIP
Feb 26, 2026
12
When I have control board connected, it burns AMS117 3.3V... and contorl board beeps repeadetly fast, but when i check after AMS117 its shorted... i replaced it a couple of times.. Control board works fine on 9V battery when connected(and AMS117 is new)...
mechtronics
Aug 7, 2011
164
is there a feedback resistor to the comp pin 3 of the IC?
FIIIP
Feb 26, 2026
12
This outputs 15V... instead of 4.7uF/25V i put 10uF/50V because I dont have 4.7/25V, and instead capacitor 333, i put 2A223J green capacitor
FIIIP
Feb 26, 2026
12
FIIIP
Feb 26, 2026
12
The two caps before the PN8024R are each 8.63uF(I guess this is together since they are connected in circuit), in circuit, for reading off the circuit, there is a table above I already sent
mechtronics
Aug 7, 2011
164
the capacitor on pin 3
what about cap connected to comp pin 3
FIIIP
Feb 26, 2026
12
The green one is 22uF i tried replacing them with 22nK100, but that didn't solved anything
mechtronics
Aug 7, 2011
164
i can see in the picture that you are missing an AC Neutral terminal where is that? you have AC Live and AC live out and AC neutral out.
FIIIP
Feb 26, 2026
12
Oh, you mean on the board, it got desoldered when i was unpluging the wire, I soldered it back :)
FIIIP
Feb 26, 2026
12
So, I replaced 2k resistor with 1k resistor, and now its outputting 12.3V...
