73's de Edd
- Aug 21, 2015
- 3,730
- Joined
- Aug 21, 2015
- Messages
- 3,730
Just a note I may have the A44 transistor the wrong way round on the drawing, it is difficult to see which way , has I am looking at it on the underside of the board and the transistor front ( flat part) is facing away from the contacts looking at it from the top .
As is being viewed from the top, the unit is being correctly installed, if the curved side of the plastic is on the side of the two black E-caps. And the flat side being FAR away from them.
Physically OPAQUE, intermittent blocking of the path of IR emitter to photocell should cause the voltage at the photocell to ground, to bobble up and down acccordingly.
UNLESS . . .considering . . that the present high ambient level of CONVENTIONAL room lighting, falling onto the photocell, with it not being being hidden down in its otherwise encased and darkened cavity . . . . would also have the potential A44 base drive voltage being grounded out by the phototransistor.
And if I remember correctly, even BLACK plastic electrical tape shielding of the phototransistor is not being an effective blocker of IR passage.
Also the ir emitter that feeds the photoelectric sensor is not lit , checked with a ir detector ! .
Sub in a properly polarity, installed conventional RED LED to observe, as it should always be lit.
Different topic . . . where was the units MICRO switch installed ?
