Parallel connection of 2 AC/DC converters
Status
Not open for further replies.
Nonespecter
Apr 14, 2013
9
Hi :)
I am working on a project with some audio and bluetooth. I ran into a little problem.
I need to have two AC/DC converters connected to the same input. but to different outlets.
1 converter AC 220V to DC 5V
1 converter AC 220V to DC 12V
The 12V is connected to an Amp and the 5V is connected to a bluetooth module.
I decided to make a parallel connection. But every time i try i cannot get any output reading.
When i try 1 alone it works fine.
Can anyone help??
Thanks in advance
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Can you upload a diagram of how you have connected them? And/or a photograph?
Nonespecter
Apr 14, 2013
9
Yep yep, hope this will do.
14,306
There's no obvious reason why this setup should not work.
What do you mean by
? Which reading?
Nonespecter
Apr 14, 2013
9
I have this electronic Voltmeter. So you can test how high the voltage is.
When i parallel connect the to converters. the voltmeter just says 0,00 (or i shifts between 0,01 and ,02. but nvm).
When i connet a single converter it reads 5v perfect.
14,306
Just to be sure: You connect the 220V inputs in parallel, the outputs are open, as shown in your diagram, right?
If you connect only the 12V converter, the voltmeter shows 12V, if you connect the 5V converter, the voltmeter shows 5V. If you connect both converters, the voltmeter shows neither 12V on the 12V converter's output, nor 5V on the 5V converter's output?
Or do you have any connections between the two converters or between the amp and the bluetooth module on the low voltage side which are not shown in your diagram?
Nonespecter
Apr 14, 2013
9
There is no connection what so ever. At the moment they are not even connected to anything. And yes i only connect 1 converter to the Voltmeter at a time :)
14,306
Can you show a photo of your setup? Your description does not fit the schematic diagram.
Does your voltmeter include a high voltage range (>= AC 400V)? Can you (while being very cautious!) measure the primary voltage (220V)? Is it at 220V when both converters are connected?
What voltages do you measure when no load (amp, bluetooth module) is connected to the converter?
Does your meter have a current range? Can you measure the currents on the low-voltage side with both converters connected?
What kind of converter are these? Transformers, or switch-mode power supplies?
Nonespecter
Apr 14, 2013
9
I just tested all the things you asked about. And it was all fine. I have no idea why it is working now.
I am gonna go through it all and check for a bad connection. Maybe my soldering skill are not as good as i thought they were :D
Thanks you for the help and taking interest.
Do i have to give some kind of thump up? or close this thread?
14,306
You can close this thread using the thread tools and unchecking the "open" box - or I can do it for you.
Status
