paralleling relay coils
I am connecting five 12V relay coils in parallel to switch five different loads. Is it necessary to have fly-back diode for each relay coil or just one 1N400x diode in parallel is sufficient? Each coil is 300 ohms.
-bhavj
U
Uwe Hercksen
the current through one coil is 40 mA, the five coils take 200 mA. A
1N400x is good for 1 A. If these five relays are not far away from each
other, only diode will do in my opinion. The current flowing through the
diode should not be much larger than the current flowing through all
coils together.
Bye
[email protected] schrieb:
coils together.
Bye
The relays stacked together and trace length is approx 70 mm from 1st relay coil to the 5th relay coil. So, do you think it would be a better option to place the diode across the coil of the middle (3rd) relay?
Make sure you use the low-voltage one, 1N4001. Higher-voltage diodes of
that series have long turn-on delays, so they aren't much good for
suppressing inductive kicks.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
Principal Consultant
ElectroOptical Innovations LLC
Optics, Electro-optics, Photonics, Analog Electronics
160 North State Road #203
Briarcliff Manor NY 10510 USA
+1 845 480 2058
hobbs at electrooptical dot net
http://electrooptical.net
Thanks. Would it be better to use 1A schottky than normal diodes like 1N400x?
The 1N4001 should be fine, but do use at least a 60V transistor to drive
the relays.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
+1 845 480 2058
BCX56 is the transistor. Relay coils are connected between emitter and ground. 12V is applied at the collector.
N
Nico Coesel
I always use a transistor or MOSFET with internal diode. No need for
an external diode.
Martin Riddle
John Larkin said:
The OP should post his schematic. I've seen interesting things, like
putting TTL levels into a base and expecting 12 volt swing at the
emitter.
I was thinking the same thing with a NPN and the collector tied to the
12v rail,
you'd need to take the Base above the 12v rail to turn it on.
Cheers
Spehro Pefhany
Sorry, you have just been demoted to SCI Electronics Basic!
Harry
Harry is right.. there are multiple issues.
1) Can we assume you're trying to drive the relays with a
3.3V CMOS output, and 3.3V in should turn the relays "on"?
1a) If so, is the common for the 3.3V supply same as the ground
shown?
2) Any particular reason you want a high-side driver
(so one side of the relays is grounded)?
3) Is this an automotive 12V system with the associated
transient issues?
4) What's with the 100uF cap across the relays, and the
0.1uF cap, for that matter?
--sp
amdx
Is that supposed to be funny?
Why is it that nobody helps the guy, rather than just letting him
know you're all smarter than him.
The more common method to drive a relay is;
+12v to one side of relay, other side of relay goes to the collector of
an NPN transistor, emitter of transistor goes to ground. Put a 1k
resistor in series with base of transistor and apply your 3.3v the 1K
resistor.
Install diode across relay.
Is there a reason you don't want to do it that way?
Mikek
*1K value can be adjusted.
resistor.
Mikek
Could be automotive relays with one terminal at frame ground, then he needs a high side switch.
Nah, your average 12V relay will pull in around 9V. 11.3ish is fat city.
Not at max operating temperature...and depending on relay design, you could be looking at 40oC core temp rise in steady state.
Spehro Pefhany
Looks like he wants to switch the coils and regulate the coil voltage
down to 12. 18V is a bit much, 2.2x the normal coil dissipation.
He could use this as a $2 one-chip solution: TL751M12QKVURQ1
(active low input).
It's possible to modify the given circuit a bit and make it work okay
too.. eliminate the caps, connect R68 to the input voltage (and make
it 10K), reduce R67 to 330 ohms, add Q1 same type as Q3, E to ground,
C to base of Q3, base to input through 2K. It will have a higher
dropout voltage than the regulator solution so examine carefully the
high ambient temperature (at the relay)/low input voltage condition.
(this is also active low input).
Best regards,
Spehro Pefhany
I scribbled a few circuits, until I ran out of paper.
https://dl.dropboxusercontent.com/u/53724080/Circuits/Power/Relay_Drivers.pdf
Oh, 1117s need an output cap.
John Larkin Highland Technology Inc
www.highlandtechnology.com jlarkin at highlandtechnology dot com
Precision electronic instrumentation
Picosecond-resolution Digital Delay and Pulse generators
Custom timing and laser controllers
Photonics and fiberoptic TTL data links
VME analog, thermocouple, LVDT, synchro, tachometer
Multichannel arbitrary waveform generators
Thanks for taking time to draw them. Yes, as you said I am trying to regulate as well as switch the power to the coils. In the fig-1, why is that pnp needed instead of resisting to limit current?
Spehro Pefhany
I've obviously led a sheltered life, since I've never seen a 12V relay
datasheet where pull-in wasn't guaranteed at well below 11.3V. Do you
have an example?
Cheers
Phil Hobbs
Hi, Phil:-
Consider a relay such as this one:-
http://media.digikey.com/pdf/Data Sheets/Tyco Electronics P B PDFs/ORWH.pdf
Pull in voltage is rated at 8.4V for the 12V nominal relay. That's
specified "without pre-energization at ambient temperature 23°C" (fine
print).
If you require the type F insulation (155°C) they offer, then the coil
resistance could then be more than 50% higher than at 23°C, so the
guaranteed minimum pull-in voltage would actually be more than 12VDC!
Somewhat less than nominal voltage is normally okay if the input
voltage is regulated and/or the environment is fairly benign, but
that's not always true. Probably sluggish turn-on doesn't help relay
life either. I don't like unnecessarily to give away voltage in a
relay driver (eg. by using darlingtons).
Best regards,
Spehro Pefhany
Spehro Pefhany
I like 7, assuming the firmware cooperates.
Possible pattern-sensitive relay operation frightens and confuses me.
Best regards,
Spehro Pefhany
