Part Replacement in Circuit
SparkyCal
Mar 11, 2020
863
I am trying to build this circuit and gathering all the parts:
The schematic for it is at 6:50 of the video.
It is a Theramin- which is a musical gadget of sorts. It makes zany noises when your hand moves toward it.
To see Lez Zeppelin use, one, see 6:15 of this videohttps://www.youtube.com/watch?v=JoTyCwRkm3I
In any event, in the video, the builder of the circuit uses a TIS58 JFET transistor (which has long been discontinued). He says he used this type, because it is what he had lying around. I don't know if that means that you could use any transistor. I looked at the data sheet and searched for equivilants, but i don't seem to have any of the equivalents listed. But I do have a whole slew of transitors, as depicted in the attached picture.
Is there anything in this army of transistors that you think I could use, in place of the
TIS58 JFET transistor.
He does say that most any JFET would work for this circuit. Is there a JFET im my pic that is a safer pick?
Thank-you
bertus
3,882
That is half a theremin.
It only controls the pitch and not the volume.
A real theremin controls both.
A theremin is not a real beginners subject.
It contains several oscilators that must be adjusted for good results.
This page has links to several theremin schematics:
http://www.thereminworld.com/schematics
And this page has some recordings of the theremin being played:
https://www.thereminvox.com/
Bertus
SparkyCal
Mar 11, 2020
863
Thanks Bertus. I will certainly check them out. The only reason I leaned toward this one, was that he has a detailed video putting it together on a breadboard. He says that Thermanins that have volume controls, get very complex. That is why I stayed away from othe rones. But if I can find a schematic in the link you provided that doesn't look too intimidating, I'd rather built it properly with the volume.
Thanks Bertus!
PETERDECO
Dec 19, 2019
239
Just in case you go back to the original circuit, substitutes for the TIS58 come up as BF256A, 2N5485 and 2SK107.
Audioguru
Sep 24, 2016
3,656
I am amazed that the circuit works when it was built on a solderless breadboard with messy long wires and their stray capacitance all over the place.
His soldered circuit needed two long wires rolled up inside to add come capacitance and the antenna length was critical.
SparkyCal
Mar 11, 2020
863
What do you think should be the appropriate antenna length?
As I explained to Bertus, I am leaning towards this circuit because it has a detailed video explaining the breadboarding, but also explaining the math. I thought it would be a good first attempt, with a view toward learning and then going for a real theremin that includes volume.
Audioguru
Sep 24, 2016
3,656
I did not hear in the video about the radio frequency it uses and I did not calculate it because of all the stray capacitance. The video mentions that it picks up radio stations. The antenna length depends on the radio frequency and amount of stray capacitance.
SparkyCal
Mar 11, 2020
863
Another question. In this video, he uses a particular transistor and references it’s drain and source. I am going to use BC537 transistors, but those commonly are referred to by collector, base and emitter. Why is the terminology different and do you think I can use the Bc537
SparkyCal
Mar 11, 2020
863
I researched it and learned that they are not interchangeable because one uses voltage and other, current. So I ordered soMe jfets. I hope I don’t already have some in that smattering of transistors that I posted.
Audioguru
Sep 24, 2016
3,656
Digikey says that the MPF102 is obsolete and is not made anymore. They have a 10:1 range of current so you need luck to find some that will work in that circuit. I hope that whoever made the ones you bought used the standard pin-out:
