PCB Laser Etching
Vagulus
May 6, 2018
26
I received the following from another forum. I though it might be interesting to some members here.
Check this out from Marco Reps
All his videos have some great info. He has PCB laser etching nailed. He's done this one and some following on how he upgraded it. Amazing results possible.
You can get the engraver here:
https://www.banggood.com/Desktop-DI....html?rmmds=search&stayold=1&cur_warehouse=CN
and a UV laser 405nm which has a sharper focused dot (see Marco Rep's videos) than the 445nm ones here:
https://www.banggood.com/450-500mW-...tail-top-buytogether-auto__4&cur_warehouse=CN
Got one myself but they're so cool it's got used for everything other than etching PCBs. Soon though....
It is a bit of an Ad and I cannot give this any recommendation, this is just FYI.
timff
Apr 13, 2018
19
The traditional chemical etch or a PCB is a comparatively slow process compared to what I would imagine a raster (or even vector) scan using a laser. A concern I would have is that the transition of the copper to a vapor (an thus its removal) would risk sputtering and thus leaving potential electrical shorts in areas of close trace proximity. Also variations in trace and pad size would greatly influence the heat (light intensity) needed to remove a particular point of copper. This might lead to areas of excessive heat and possibly contribute to potential delamination problems.
14,317
The laser isn't used to vaporize the copper, it's used to vaporize the masking paint followed by traditional etching.
I've been using the laser ablation method of PCB manufacture for some time.
edit: See here.
Recently I've seen an approach where a blue laser is used to expose photosensitive PCB.
The problem with all the laser ablation techniques is getting all the resist layer off without damaging surrounding resist. This is less of a problem if you're using the laser to expose the board, but then you need to be careful about stray light fogging the emulsion.
FuZZ1L0G1C
Mar 25, 2014
366
Thanks for the share @vagalus.
Definitely going to investigate this option further...
