PCB photo/etch chemicals
Ade
I'd like to, occasionally, make my own PCBs for "stuff". The key here is
"occasionally"...
I'm sort of assuming that, short of using a commercial fab house (which
is expensive), I'll either need to use a "pcb-in-a-bag" type kits, or
the various chemicals. I'm thinking that I can either do:
Fotoboard + etch resist remover + ferric chloride
or
Plain board + photoresist + resist remover + ferric chloride
Assuming one one of the above 3 options (bag, Fotoboard version or Plain
board version), which is likely to survive the longest under a cupboard
without the chemicals losing their ability?
Rich Webb
"occasionally"...
or
You might consider the Press'n'Peel Blue stuff, used with the laser
printer toner transfer technique. The sheets should be shelf stable as
long as they're kept in the package and away from dust, debris, and
excessive cat hairs.
The most consistent results are probably obtained with a fuser, like a
GBC laminator, although some folks report doing just fine with only an
ordinary clothes iron. One could also use inkjet glossy photo paper
(printed in the laser) as the transfer medium but that's a bit messier
since the photo paper needs to be soaked loose in water.
I get clean 10/10 results with the P'n'P medium, although 15/15 is more
comfortable.
Ade
Good idea, yes, thanks. I'd read up about that stuff recently, but
forgot about it when I posted. Ta for the reminder.
The only hassle I've seen mentioned about the laminator is it needs the
extra-thin boards, a full 1.6mm double-sided fibreboard won't go through
it (according to the specs, at least).
comfortable.
Apologies, I'm not familiar with what 10/10 or 15/15 mean? Is it the
width of tracks/gaps in microns?
Rich Webb
Once upon a time, the folks over at Pulsar
http://www.pulsarprofx.com/PCBfx/main_site/pages/index.html
had instructions on how to modify a GBC H200 model laminator to accept
standard 1/16" (1.6mm) stock. I looked around over there and those
instructions are long gone, as well as that laminator model. A link at
http://www.picbasic.org/showthread.php/51159-.032-Pcb suggests that
there was a UK model "GBC Docuseal 95P laminator" that may have been
equivalent and *if* you can find one in working condition, we may be
able to find or re-engineer the mods necessary.
<clickty click> Aha! http://www.qsl.net/ve2emm/pcb/pcb_mach_mod_e.html
For what it's worth, I did the mod and it does work with 1/16" now, but
I have found that I actually prefer using 1/32" (0.8mm) material. It
cuts with tin snips (or even heavy scissors) and there is less mess from
drilling.
Yes, but in US-ian mils (thousandths of an inch).
Cydrome Leader
"occasionally"...
or
the ferric chloride is good forever. just check the container from time to
time. sometimes they do weird things like shrink or look sucked in.
Ade
The best etchant I've ever used "d-i-y" is muriatic acid (from the
handyman store) activated 5:1 with hydrogen peroxide (from the drug
store).
OK, thanks. Can you give me an idea what products muriatic acid is in?
Also, what concentration of h2o2? ta.
Pete Wilcox
Muratic acid is the product. It's used to clean concrete and in
pools.
I've never seen the point, meself, in going to all the trouble of etching
a board for a one-off project. Stripboard is far cheaper, simpler and
quicker to use.
Cheers,
Pete.
Cydrome Leader
muriatic acid is hydrochloric acid. it's sold in 1 gallon jugs in the US
at hardare stores. I'm not sure of the concentration, but even the
smallest splashes will eat holes in clothing and burn skin.
gostop2000
Jul 12, 2010
7
This is Simon from Shenzhen Smart Power Technology Co., Ltd. One of leading PCB manufacturers in Shenzhen, China.
We can provide all kinds of PCBs with the highest industry standards of quality within a short lead time.
Our price is competitive because we have our own factory. This may reduce your purchasing cost. We are very glad to receive your inquire.
Our most advantage as following:
Rigid-flex circuits (1-8 layers)
Blind Buried via PCB (6-18 layers)
HDI PCB (6-18 layers)
Plugging vias
Complex sample project
3 mil line space/width.
Heavy Copper (up to 10 OZ.)
Aluminum Based PCB (LED lamps, module)
Max Panel Dimension: 1024mm*1024mm
Mobile Phone Board
Power supply module
Please give my best wishes to you and your family.
Sincerely Yours,
Simon
gostop2000
Jul 12, 2010
7
PCB
Plugging vias
Mobile Phone Board
Power supply module
Sincerely Yours,
Simon
________________________________________
Shenzhen Smart Power Technology Co.Ltd
Tel: (86-0755)-29589452 Fax: (86-0755)-29589453
Skype: gostop2000
www.smart-pcb.com
[email protected]
Add: Baoyuan Building 706, Baoyuan Road, Xixiang, Baoan, Shenzhen, China
