PCB photo etch using inkjet?
  • Thread starter Abstract Dissonance
  • Start date
Abstract Dissonance
I just opened up a kit I have for photoetching and it says that inkjet will
not work ;/ I thought I read that you can use inkjets for making the
transparencies? I don't see the problem unless somehow the ink reacts with
the UV light or that the UV light can penetrate through the ink? Any ideas
about this?
Jon
JazzMan
about this?
Jon
If you're talking about the photographic process where a
sensitized board is exposed to light with the artwork on
a transparancy, then the inkjets typically don't get dark
enough for fine line work. Laser toner is much more opaque
than any of the inkjet inks I've seen so far.
JazzMan
Please reply to jsavage"at"airmail.net.
Curse those darned bulk e-mailers!
"Rats and roaches live by competition under the laws of
supply and demand. It is the privilege of human beings to
live under the laws of justice and mercy." - Wendell Berry
Tom Biasi
JazzMan
Also there are methods that rely on the fusing of the toner to the board.
Ex. PNP Blue.
Steve Butler
ink doesnt dry quick enough consequently it runs or smudges edges
I have done a board or two printing artwork to plain paper and
exposing for a minute or so in sunlight , worked well but now
use Laser printer and transparencies for development
Steve
steamer
--IIRC the trick is to take the inkjet rendering and photocopy it
onto that special paper that can then be ironed onto a copper substrate to
make the mask.
Abstract Dissonance
make the mask.
"Steamboat Ed" Haas : Woohoo! Cheney sez
Hacking the Trailing Edge! : lawyer season's open!
http://www.nmpproducts.com/intro.htm
---Decks a-wash in a sea of words---
Yeah, but I'm was going to use UV since I didn't have a laser printer. I
didn't see any mention of not being able to use UV with inkjets ;/ Else why
use UV? (spend !70$ on the UV exposure device and transparencies and
stuff... kinda a waste if I have to use a laser printer anyways.)
Abstract Dissonance
Steve
Do you mean the UV wil expose through a plain sheet of paper?
if that was the case you could always run it through the printer a couple of
times(although it might mess up very fine traces).
DJ Delorie
I read once that the trick to using inkjets with photoexpose is to
print in green (using cyan and yellow inks), not the black ink,
because those colors blocked UV the best. Print some color bars and
do a test board to see which of your inks (or combinations of inks)
block the most UV.
Abstract Dissonance
Steve
I tried printing the traces on a transparency with my inkjet and it turned
out almost perfect. There were no smudges or anything and it looks pretty
dark(it has a green hue to it though and I'm not sure if my printer is using
the black ink completely or not.) I'd say its 99% perfect as far as the
traces are concerned. There is a little "streak" about 1 mm long through one
of the traces but that is easily fixed. I will go ahead and try it and see
what happens. Hopefully the ink is thick enough to block the UV light. I
might post my results if they are decent.
Jon
Rich Grise
about this?
The ink washes off.
However, you _can_ use an inkjet if you copy it on an ordinary xerographic
copier, since the toner is plastic; inkjet ink is just ink. (you _do_ have
to heat-set it, however.) Laser toner will also work, i.e., if you print
the pattern on a laser printer - they use the same plastic toner as
copiers.
Good Luck!
Rich
Rich Grise
OK, wait a minute - we're talking apples and oranges here.
If you have a board that comes precoated with photosensitive resist, then
anything that will expose a pattern will work, albeit if I was going to
use an inkjet I'd get coated transparencies to print on, and print
reversed; if I really wanted tight precision and only had an inkjet,
I'd print it 2X or 4X, physically cut and paste the paper pattern, and
take it to a photo shop.
If the PCB is just plain copper, then you'd use the laser printer toner
or copying machine toner as the actual resist. Inkjet will _not_ work
for this, because the ink is just ink; there's nothing to transfer.
With laser or copier, you just take the sheet out, verify the dimensions,
and lay it face-down on the copper and iron it on. You also have to print
reversed when doing this.
Hope This Helps!
Rich
Abstract Dissonance
using the black ink completely or not.) I'd say its 99% perfect as far as
the traces are concerned. There is a little "streak" about 1 mm long
through one of the traces but that is easily fixed. I will go ahead and
try it and see what happens. Hopefully the ink is thick enough to block
the UV light. I might post my results if they are decent.
Jon
So far so good. I was able to get the layout on perfectly. I could not place
a "weight" on the transparency since the ink would not try. I have to cut
the board to size and etch it. I was able to get about .008 trace width.
Don't know for sure since I didn't use any traces smaller than 0.040 but
my - sign's have a smaller than 0.01in so I guess its about 0.008.
So I guess everything is ok now. The etching should be routine(well gotta
figure out the proper time). The next hurdle will be the drilling.
Jon
Abstract Dissonance
place a "weight" on the transparency since the ink would not try. I have
to cut the board to size and etch it. I was able to get about .008 trace
width. Don't know for sure since I didn't use any traces smaller than
0.040 but my - sign's have a smaller than 0.01in so I guess its about
0.008.
Jon
The etching went almost perfect as far as the traces are concerned. It was
a little messy and the process wasn't perfect as far as efficiency and ease
of use but it was cause the way I did the tank and the stuff I used. One
thing I didn't expect was for the etchant to screw with the airator I used.
It was one of those stone string things that let the bubbles through. The
etchant ate through some of the stone for some reason ;/
The board itself is ok though. One of my G's(for ground) got ate through a
little but everything else is ok.
Next thing is the drilling ;/ I figure this will be the toughest but if it
goes like the others then it should be a piece of cake.
One thing I should mention though is that using the inkjet transparency
method lets use reuse the transparencies pretty easy. You just was off the
ink(I used the developer and it came right off. I'm not sure if it would
work with the toner though.)
Jon
Rich Grise
the ink(I used the developer and it came right off. I'm not sure if it
would work with the toner though.)
Yeah, tell us how well it comes out after washing off the coating. ;-P
FYI, the transparency film I've ink-jet printed on came with a special
coating that retains the ink like paper does - bare mylar or acetate
will just smear. But, I don't know if it unconditionally destroys the
coating to erase or wash off the ink - try it and let us know, OK?
Good Luck!
Rich
Abstract Dissonance
Good Luck!
Rich
I just got finished drilling the holes. It seems like it will work. While I
didn't do the best job drilling the holes I think its good enough. The main
problem was the bits I were using just were either to big or to small. They
were not standard drill bits but the ones that came with the dremel.
Heres a photo of it:
http://www.geocities.com/abstract_dissonance/FirstPCB1.jpg
The large thick lines are 0.06in and the smaller ones are 0.04. Being my
first pcb I'm supprised it went so well. Was expecting much more trouble.
Most of the real trouble was seting up the etching and such as my home made
tank was a little to big and the fact that it ate through my stone bubbler
thing. Cleanup was a little trouble too. But it was definately not as much
trouble as I thought it would be. I mean, for one 2.5x2.5 board it is but
making several at once would be quite efficient except for the drilling.
Hopefully my traces are right so I my circuit will work ;)
Going to try and tin it now then add the components.
Jon
Rich Webb
Looks quite nice!
Abstract Dissonance
Rich Webb said:
Looks quite nice!
I think so too ;) That is for being my first time. I learned a few things
along the way and I still came out of it with a usable PCB ;) Not sure why I
was so anxious about doing it.
One thing I did learn is that you should remove the resist before you drill
holes. Else it seems to make it awful difficult to tin.
Jon
Bob Masta
A home tanning lamp makes a good cheap UV source.
You may be able to find one at an estate sale of
a skin cancer victim. <g>
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
Rich Grise
drill holes. Else it seems to make it awful difficult to tin.
And get a smaller drill bit or two. ;-) Although, there are folks who
recommend a dental bur. (burr?)
Cheers!
Rich
