PCB production
vick5821
Jan 22, 2012
700
As an engineer , you are needed to design a PCB for your company's product.The product should handle a larg amount of current and very sensitive to noise. Explain two criteria for you to consider before building your PCB.
Any ideas guys ? Please help
Thank you
Is there anything that you can suggest might help? Perhaps if you miss something or don't quite get it right we can set you straight.
CocaCola
Apr 7, 2012
3,635
There are lots of things to consider, trace width, trace thickness, routing, application, product environment, possibly using internal (or external) layer ground planes for shielding, what parts or areas might be shielded blah blah blah
vick5821
Jan 22, 2012
700
ya..trace width can be increase for high current..why? And how to deal with sensitivity to noise?
CocaCola
Apr 7, 2012
3,635
Are you making a trace that handles the load or a fuse? Both trace width and trace thickness will make that difference...
I tossed up several options to consider, there are of course others...
vick5821
Jan 22, 2012
700
This is a type of exam question.Btw, just to ask, how does increase in the net thcikeness/width can sustain more current ?
