PCF8575
Sai Shoby
Oct 13, 2020
4
unsigned short PortP0 ;
unsigned short PortP1 ;
void main(){
I2C1_Init(100000); //100 KHz // join i2c bus
while(1)
I2C_Start();
I2c_Write(0x43); //Read Address
PortP0 = I2C_Read(0);
PortP1 = I2C_Read(0);
I2C_Stop();
if(PortP0 == 0b11100001) //Making Bit 0 high
I2C_Write(0x42);//Setting the Slave Address for PCF8575. Write Address
I2C_Write(0b11100000);// first 8bits
I2C_Write(0b11111110);// Turn on led on Bit0
Hi all,
I am trying to control switches in PCF8575 through I2C, when I press the switch which is connected in port0 in PCF8575, I want to glow the leds which i connect in port1 of pcf8575. i attached code. I cant able to read the switch status. Please help me to solve this. Switches are connected in po,p1,p2,p3,p4 with pull down resistors and leds are connected in p12,p13,p14,p15 with pull up resistors in pcf8575
HarryA1
Mar 4, 2009
481
What are you connecting the PCF8575 to?  You most likely need to include some type of library.
