[email protected]
- Jan 1, 1970
- 0
It's not clear to me why this needs to be resolved by the BIOS.
First, the fact that the card is placed at a high memory address
is unrelated to caching. The BIOS putting things at high
addresses is convient to avoid things at low addresses (such
as the 2G of RAM you might have). But that doesn't make
the area unworthy of caching.
Second, what kind of device would sit on the PCI bus that is
simple enough to not need a device driver and yet requires
caching to be turned off for that area?
The only bits in the PCI configuration space that go with the
request for a range of memory are: prefetchable, type (2 bits
identifying where it can be placed) and a memory versus
I/O flag. That's all the BIOS has to work with.
Why would a device on the PCI bus not want to have its
memory range cached? Because the memory can change
by means other then the system CPU. For example, our
cards have serial chips which have their internal registers
mapped to PCI memory space. If the CPU writes to one
of these, it can't be cached -- it needs to go right through
to the memory/register immediately. Likewise, the CPU
can't refer to its cache to get a value. The registers change
all the time based on what's going on on the serial line.
So any cache would instantaneously be "dirty".
The above card would be useless without a device driver.
What kind of situation are you worried about needing to
have the PCI device's memory range uncached that is
simple enough to not need a device driver?
Steve
Steve
