PCI-X pin out?
N
NAW
Where can I get the spec on PCI-X pinout?
Also does it have 5V power available?
Nigel.
Roger Hamlett
Nigel.
PCI-X, has the same pinouts as PCI. You have the extra connector for the
64bit version, and it can run at a faster clock. Pinout:
http://pinouts.ru/Slots/PCI_pinout.shtml
If instead you mean PCI-Express, then:
http://pinouts.ru/Slots/pci_express_pinout.shtml
PCI-X, has 5v available (even on the 3.3v versions, there are a couple of
5v pins), but PCI-Express,only has 3.3v for the logic, and 12v for things
needing higher voltages.
Best Wishes
N
NAW
Best Wishes
Thanks Roger,
It was the -X I was after, I couldn't find any references to the
availability of +5V on my searching.
Best wishes,
Nigel.
