Codyhtml said:
ok thanks but for the project i started i'll have to find a way yse a perf bord just have tons of holes and a little coper "O" around the ring
Yeah there are no connections on the board, those are just places to solder your component leads.
What you do is place the two wires in two holes close to each other, and make a solder bridge, or just bend one of the wires over a little to make it easier. And if they arent close then you can use some wire on top of the board to connect two points.
Here is the only decent example picture I could find:
I think the only reason hes using the large copper wires below is the power in the circuit. Not needed on normal boards.
btw I use these boards a lot, its very easy to wire up a schematic.
