Phase detector for huge jitter ??
5
5hinka
How to build a phase detector??
I know that normal design is two flip-fops and NAND gate but it works only
with phase difference between signals smaler than 1 (T). How could I
possibly build a phase detector when phase difference between signals is up
to 10-20 (T)?? It could be hole digital or digital/analog solution.
Anybody know any suitable links??
Greetings
5hinka
Jim Thompson
Greetings
5hinka
Are you saying you have jitter that is up to 10-20*T?
How could you ever define that as "phase-locked"?
...Jim Thompson
Tim Wescott
Greetings
5hinka
(a) divide both signals by N and use a 3-state phase detector.
(b) make an extended state phase detector.
Both of these methods are detailed in "Phase-Locked Loop Circuit Design"
by Dan Wolaver, Prentice-Hall 1991.
5
5hinka
IEEE is saying that jitter in 2Mbit signal (HDB3) can have jitter up to at
least 5 T is jitter 10-20*T isnt very big.
Greetings
Jim Thompson
Greetings
I think you should be surfing for "Clock Extraction".
...Jim Thompson
Tim Wescott
...Jim Thompson
FM transmitters that use phase-locked signal generation can have
phase-locked loops with this much phase difference.
NRZ digital signals that have gone through a number of repeaters can
have short-term jitter that is this severe.
You define it as "phase-locked" if the average phase and frequency of
the locked and input signals match, and if your phase detector never
actually looses track.
See the reference in my other thread. I took the class from the author,
he really knows what he's talking about.
Jim Thompson
Classic phase detectors fail on NRZ, but there are a variety of
methods to extract a clock from such messes.
...Jim Thompson
Tim Wescott
Jim said:
On Wed, 21 Apr 2004 09:34:13 -0700, Tim Wescott
-- snip --
...Jim Thompson
Minor detail. Actually if you have data that "jitters" by 10-20T then
you probably need to have a fast clock extraction loop that gives you a
nice clean digital clock followed by a clock regeneration loop that can
stand the huge phase difference, because all the edge detection schemes
are digital, and all the clock extraction schemes have some very analog
properties.
5
5hinka
...Jim Thompson
Im building jitter measurer for 2MBit signal.
| estimating |
| clock |
-IN--|Extract. |------ ---------| Phase |
|clock |----------------------------| detector |
Estimating clock will be in different time periods.
I have already Extracted clock from 2MBit HDB3 signal.
I think that i will estimate clock on PLL changing FPD filter for different
time periods.
The hole problem now is to build Phase detector for such big jitter.
F
Falk Brunner
time periods.
Simple. Use a 4 bit counter for incomming clock and local VCO. So the
compare frequency is then 1/16. With the normal Phase detector with a
working range of one period (T), you have a 16 T working range on the
desired frequency.
Regards
Falk
Allan Herriman
Greetings
5hinka
The huge jitter only occurs at low frequencies.
Firstly, let's fix the terminology. Your 'T' is more commonly
referred to as a Unit Interval (UI) when measuring jitter on a 2Mbit/s
circuit.
According to ITU-T G.823 (and a few others), the maximum tolerable
jitter on an E1 is 1.5UIp-p in the band 20Hz - 2400Hz, and 0.2UIp-p in
the band 18kHz - 100kHz. Other specs indicate that the jitter /
wander may be as high as 18us p-p (36.8UIp-p) in the band from (1/1
day) to 0.8138Hz. (If you draw this on a graph, there's a nice
-20dB/decade slope between the segments.)
Since you are making test equipment, you should be able to generate
and measure jitter with a higher amplitude than this, say by at least
6dB. Your 10-20 UI figure sounds reasonable, but only at mid
frequencies.
I suggest that a more reasonable specification for test equipment
would be:
80 UIp-p, for frequencies up to 0.81Hz
3 UIp-p, for frequencies between 20Hz and 18kHz
0.4 UIp-p, for frequencies greater than 18kHz.
I assume you are tracking the incoming phase with a PLL. If the PLL
has a loop bandwidth of > 1.5 * 18kHz, the phase detector inside the
PLL will never see a phase difference of more than 2 UI p-p, which
means that a standard phase detector can be used without going outside
its linear range.
Regards,
Allan.
