Philco ac outdoor unit PCB ce-kfr90gw/i1y
maneshnandwani
Oct 1, 2018
5
I have the above captioned board that got wet due to a typhoon and am trying to figure out which part is damaged. The led light turns on but starts blinking after a couple of mins as both the compressor and fan does not turn on and at the same time indoor unit shuts off also.
maneshnandwani
Oct 1, 2018
5
maneshnandwani
Oct 1, 2018
5
That's the old board and I bought a new board but the new board doesn't work, so I'm trying to repair the old board.
dave9
Mar 5, 2017
1,191
First, have you used a multimeter to determine that when the compressor should turn, it is outputting the voltage to it? I mean trace the relay that activates it and see if it is closing the circuit or failing to energize the relay coil to do that.
maneshnandwani
Oct 1, 2018
5
Thanks dave9. I used a tester to check output post relay and there is current being produced.
dave9
Mar 5, 2017
1,191
You can't measure current produced unless it is delivered through the load. Measure whether there is appropriate voltage at the compressor and fan.
I will say that one of the common faults on an A/C system is that the compressor (or fan motor) capacitor has failed.
maneshnandwani
Oct 1, 2018
5
I will say that one of the common faults on an A/C system is that the compressor or fan motor capacitor has failed.
I can manually engage the ac contactor that switches on the compressor so the compressor is working. I am pretty sure that there is something only wrong with the pcb as I have switched the pcb from an identical a/c and it works.
kellys_eye
Jun 25, 2010
6,512
You have two boards, one of which is 100% ok. It should be a simple matter to make comparative test between the two.
Start by measuring the voltages around IC1 (appears to be a voltage regulator) then the transistors.
