Philips 30PF9946D/37 LCD
Hello! I have a Philips 30PF9946D/37 30" LCD that no longer turns on.
Upon pressing the power button, the status LED goes from green to
amber then to red.
Is this a common problem with these?
Thank you!
Leonard Caillouet
amber then to red.
Thank you!
They were Philips products.
Leonard
Arfa Daily
Max said:
Could be ps board.
It's a common problem with all LCD TV sets. First, try unplugging the
display panel's backlight inverter board. It is very common for these to
fail and cause the set to revert to standby. Otherwise, it's most likely
that the PSU itself is faulty - also very common.
Examine it *very* carefully for bulged electrolytics on the secondary side.
Note that these may be 'hiding' under bits of heatsink, so look carefully.
Also, check all large and heatsink-mounted devices, for bad (lead-free !!)
joints, which is another common cause of your described symptoms. Other than
this, you're a bit 'on your own' with LCD sets. There are other possible
causes, such as bad sound output chips, but if you really do have a power
supply problem that's not one of the things described, then you will
struggle to get to the bottom of it without schematics, and an intimate
knowledge of switchmode power supplies. These LCD ones are infested with
monitoring circuitry for output voltages and over-current conditions, and
they all work on the standby supply, so if *any* unexpected condition is
detected either at startup, or during use, the standby supply is momentarily
stopped, which causes the system control micro to reset back to its 'sleep'
condition, removing the 'power on' signal to the power supply. Depending on
the set, that may then be an end to it until you try to bring it out of
standby again, or it may just keep trying on its own, causing a flashing
power light.
If you can prove which board is causing the trouble, you might want to
consider just replacing that board. PSUs and inverters for many sets, can be
found astonishlingly cheap on the 'net and e-bay sometimes.
Arfa
Thanks for all the great answers you guys. I was leaning towards the
power supply issue. Another thing I notice is that when I initially
turn the TV on, a relay clicks on (most likely on the PSU), then as
the status LED goes to red, it clicks off. If I turn it on again soon
enough, I can see the backlight flash for a split second.
I've had good luck repairing PSUs with noticeable parts that have gone
bad (ie, electrolytic capacitors that are clearly not feeling well),
so I'll check this one out, too.
I'll check the outputs of the PSU to see if they are within ranges
that are standard (3.3, 5, 12, etc). Hopefully I can find my long T5
torx screwdriver since driver bits are too thick...
