Philips monitor: fades out and zooms
Equinox
Hallo!
I bought a used Philips 109B.
When it is cold, after few seconds it zooms in and fades out, and the screen
is black.
What could it be? A condenser?
Thank you
E. - Italy
Arfa Daily
Equinox said:
Hallo!
screen is black.
Thank you
E. - Italy
Sounds like the HV to the CRT final anode is dying off. Could be almost
anything ...
Arfa
Equinox
anything ...
Arfa
Thank you.
I forgot to say that when it is not cold (after 5-10 minutes) it works well.
E.
Arfa Daily
Equinox said:
Thank you.
well.
E.
Then a bad cap, or possibly a bad solder joint, are first favourites.
Shouldn't be that difficult to locate with a can of freezer and a hair
dryer. Does it definitely 'balloon' as it fades ? Often, a fading display on
a CRT monitor, is down to nothing more than bad joints on the tube base
heater pins, but in that case, it is just a gentle fade away to black, with
no real alteration is picture size.
Arfa
