Phillips 50" Plasma Repair Parts Needed - Model 50FD9955
James W
I was wondering if you guys could help me...
I have recently inherited a dead 50" Phillips Plasma monitor. This
monitor worked fine up until 6 months ago. When I press the power
button, the green "on" light appears and I hear a click, but there is
no display (there are two 5" fans in the housing, they do not spin up
either). The first thing I thought was that the power supply was
dead, so I removed the back cover and found the board. On the board,
there are three small burned areas where some of the components have
shorted out. This monitor is out of warranty, and according to
Phillips, is not available for after warranty repair. The Phillips
help desk person I spoke with gave me a few phone numbers for local
repair shops, but told me that they would not sell me the replacement
part I need directly...which means parts + labor. Since the power
supply appears to be the only damaged part of the entire display, I'd
like to obtain only the part I need and replace it myself. Here is
the pertinent info:
TV Model: Phillips 50FD9955 50" Plasma Monitor
Product Link: http://tinyurl.com/c5a4n
Defective Part: PNT-503
Manufactured by Origin Electric Co. LTD (made in Japan)
Specs:
Input AC 100-240V
50Hz/60Hz
7.1A
Output +170V 2.0A, +70V 2.6A, +5V 5.0A, +5V 1.1A, +3.3V 4.0A
+7V 0.5A, +14V 1.0A, +6V 0.3A
The following marks are at the bottom left of the board:
3S110071
(PNT-503)
PKG-1939
I've been scouring the web looking for a source for this board, but so
far, my search has been fruitless. It would be a shame to throw this
thing away, especially when it may only need one part. Of course,
there is a good chance that the damage is more extensive than I can
currently tell, but I think it's worth a shot. If anyone can provide
any help on sourcing this part (or a compatible replacement), please
let me know. As a side note, I have very little experience with board
level repairs, so I wouldn't be able to repair it myself...but if you
know someone who could, then that would be helpful too. I am
including a link to pictures of the board.
http://img185.imageshack.us/my.php?image=board7uy.jpg
http://img345.imageshack.us/my.php?image=damage14xf.jpg
http://img345.imageshack.us/my.php?image=damage22bi.jpg
http://img345.imageshack.us/my.php?image=damage30wn.jpg
Thanks in advance for your help and for taking the time to read this
post.
James
James Sweet
the pertinent info:
Specs:
Input AC 100-240V
50Hz/60Hz
7.1A
3S110071
(PNT-503)
PKG-1939
post.
James
The problem may be only the power supply, or there could be a fault
elsewhere that burned it up. Your best bet is to take it to a shop that
works on this sort of thing, they'll be able to repair the existing power
supply at considerably less cost than buying a new one. Plasma sets are so
complex there's really not anything anyone here can do to help you fix it on
your own.
I
Inty
your own.
Yes, but it's only a switching psu...
I.
Andy Cuffe
the pertinent info:
It's hard to tell exactly what those parts are from the pictures. The
power supply is probably repairable, but it's not a good do it
yourself project. Switching power supplies can be difficult to
repair, particularly ones as complex as that. If you miss one thing
it will instantly blow all the parts you replaced plus it could cause
serious damage to the TV. Since the TV was free, it's well worth
putting a few hundred into it.
Andy Cuffe
[email protected] <-- Use this address until 12/31/2005
[email protected] <-- Use this address after 12/31/2005
It is only a switching psu?
With no service information or schematic available and multiple burnt
components including several surface mount burnt components and landing
pads.
FYI it is probably the 7 or 8th one I have seen the psu board look like
that. Our field tech was quite busy replacing the power supply on the
Philips Plasma in the last year all with catastrophic burnt failures.
Seems Philips has another wonderful engineering problem.
Philips has paid for a couple that were out of warranty when they
failed to the first owner. They had to call with receipt in hand and
all information available AFTER an authorized tech performed the
evaluation. Good thing though as a third person tried to fix
themselves and had the back of the set when the tech arrived, customer
service denied as an un-authorized person was inside the set.
