Phoenix Contact 24vdc 40A power supply repair
bigone5500
Apr 9, 2014
712
I got a power supply from work out of the recycle bin. This is the one I have. I connected 110v to it and there is no voltage on the output side. I will take it apart and do some testing to see what I can find. I have taken it apart once but just to see if the fuse was good and it was. I think this unit retails for around $900 so I think it would be worthwhile to repair if possible. I did a quick look over and found that the small filter caps on the output are swelled. I am wondering if the transformer on that side is bad. The caps are 35v 1200uf and there are 4 of them. The large caps look to be ok. They are 420v 390uf.
I am starting this thread for reference. I also would like input for what to look for and tips on troubleshooting these things. I do know that when working with this type of equipment that safety is paramount. Large caps can hold charge for a long time and are lethal.
14,487
highly unlikely that the transformer would have failed
caps and semiconductors would be the first choices
Minder
Apr 24, 2015
3,561
That is a SMPS type, so I would check the large semi conductors for a start, replace any bad looking caps.
The transformer is a switch mode type and a shorted turn is a possibility.
M.
bigone5500
Apr 9, 2014
712
Took it apart and found another component that I think may be bad too. There is some smoke around it and the solder joint looks iffy too.
14,487
yeah seriously dry jointed and have been arcing
