phone doesn't charge sony xperia xz premium
qok4959
Mar 6, 2022
I had recently some problems with charging my phone. I had to hold my cable at certain angle to get battery charged. Cable or charger are not the problem here, because I've tried to charge it with many other substitutes.
I thought the problem may be the charging socket, so I've decided to change the socket itself, but the problem was the same after changing the socket.
(I think any tape was barely connected and when I had to hold a cable in a certain angle, then it get connected, only my silly thoughts about it D: ). I think there might be some problems with any tape or battery.
Thanks in advance for interest in my thread =)
Martaine2005
May 12, 2015
5,318
Clearly there is a connection problem that’s remedied by holding the cable at a certain angle.
Changing the connector would only work if that’s faulty with bent pins etc.
You clearly have a broken PCB trace or cracked PCB. A magnifier will prove this.
Martin
