Photoflash capacitors and Charging
Status
Not open for further replies.
T3rr0rByte13
May 1, 2016
I must confess I am very new to electronics. I have 3 capacitors (80uf, 330volt) wired in parallel, then a switch, then a 1kΩ resistor, then I have 2 AA batteries to charge the capacitors. Got the circuit built, ready to flip the switch and monitor the voltage of capacitors, however I have no idea what is likely to happen. Questions I have:
1. about how long do I have until the capacitors are fully charged?
2. if I take too long to switch the charging circuit off will the capacitors explode?
3. how dangerous is what I am doing?
cjdelphi
Oct 26, 2011
1,166
How long to charge them? With just 2 aa batteries? ... never
Not dangerous at all without extra circuitry
T3rr0rByte13
May 1, 2016
What would you recommend that I charge them with? My idea is to discharge them into a coil, I am making a coil gun of sorts.
Colin Mitchell
Aug 31, 2014
1,416
You need to see the coil gun article where you put a projectile in the barrel and fire it at a person and it kills them immediately.
A really fun project.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
What is "a coil gun of sorts"? What will you use your "coil gun" for? What type of projectile will your "coil gun" launch? How fast will the projectile be when launched from your "coil gun of sorts"? What is the mass of the projectile? What is its size and shape? Will it be dangerous, perhaps lethal, for a living organism to intercept the projectile while it is in flight? Your answers to these questions are of great importance to the life of this thread.
cjdelphi
Oct 26, 2011
1,166
Can't a low voltage super cap be used? 2.7v 500f for less than $10 will put a photo cap to shame...
I suppose the the copper coil would need to be quite a lot thicker than it's high voltage counterpart
14,487
Thread closed
because if this is done correctly, it is a dangerous project
please reread the rules you agreed to when your signed up
Status
