Photon detectors
CommanderLake
Oct 2, 2012
227
I was looking for something on Digikey and I came across this, I knew photon detectors exist but I never looked into how they work, It seems to use a plain old photodiode.
I have some 5ns photodiodes and some experimenting showed that its impossible to have the best possible speed and sensitivity at the same time and to detect individual photons you need extreme speed AND sensitivity.
So how is it possible to detect individual photons with a photodiode, what circuit do they use?
14,317
This device doesn't use ordinary photodiodes. It uses avalanche photodiodes to achieve very high sensitivity.
At least that is what they state in the datasheet:
The SPCM-AQRH uses a unique silicon avalanche photodiode (SLiK) with a circular active area, achieving peak photon detection efficiency greater than 70% at 700nm over a 180µm diameter with unmatched uniformity over the full active area.
CommanderLake
Oct 2, 2012
227
I discovered that, maybe I overlooked it because I had no idea avalanche photodiodes exist.
Why is it so expensive?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
@CommanderLake: You just might be in a little over your current level of competence on this one.
Avalanche conduction can occur when a diode is reverse-biased sufficiently. It is distinguished from ordinary reverse-biased zener conduction by being a "positive feedback" mechanism that can quickly lead to self-destruction (through excessive current) unless "special measures" are taken to prevent this from happening. Photo-diodes operated as avalanche diodes are reverse-biased very near the avalanche conduction threshold, which allows an incoming photon to initiate an avalanche event resulting in many more avalanche conduction electrons flowing through the diode junction than the original photo-electron that was absorbed. These devices thus respond to single photon events.
Not ALL photons will be absorbed and produce an avalanche conduction... that depends on the quantum efficiency of the photo-diode... but QEs greater than 80% with some approaching 90% are not uncommon. Hamamatsu (Japan) is a world leader in the manufacture of this type of photon detector. Here is a link to a very nice discussion of some of their avalanche photo-diode (APD) products.
Back in the late 1960s or early 1970s (I forget which) I was asked to help a newly degreed electrical engineer, who had "come up through the ranks" as an electronics technician, obtaining his BEE degree through part-time study. He was trying to use an avalanche photo-diode to detect a phenomenon that pretty much everyone who knew anything at all believed didn't exist: a time delay in the onset of Faraday rotation of polarization of light. The Air Force was VERY interested in proving the so-called Allison Effect existed and could be used to identify contamination of lubricants and fuel down to levels of a few parts per billion. They had some in-house money to spend on this project, which was not very sophisticated in its design, but it did depend on a human observer manipulating several lecher-line shorting bars and observing a dimming of the nearly nulled, polarized light, optical field.
The lecher lines were connected across a spark-gap, discharging the lines periodically, and whose brief arc-light illuminated the optical path of the instrument. I never was afforded the opportunity to "try out" the instrument, but all the experiments and adjustments had to made in near-total darkness to allow the human eye to become "dark accommodated," so the dimming of the visible field could be observed as the shorting bars on the lecher lines were adjusted. However, not all observers were equally successful in operating the lecher line controls, nor were their setting of the controls consistent among observers. For this reason, mainly, the Air Force insisted on a demonstration using photo detectors and electronic instrumentation.
IIRC, many types of photo detectors were tried unsuccessfully, beginning with photo-multiplier tubes and finally ending with PIN diodes and avalanche photo diodes. There were lots of problems with stray electromagnetic interference because of the lecher lines (exposed in air) and the high-voltage discharge of the spark-gap illumination source. These lecher-line currents were also used to excite a solenoid around the transparent liquid-sample holder, said current being switched on and off by the spark-gap switch.
By the time I got involved, Herb (the technician who was now an engineer) had managed to destroy his very expensive avalanche photo diode by reverse-biasing it with DC without an adequate means to limit the avalanche conduction current. He hadn't even taken the precaution of operating the device in total darkness while messing around with the bias, much less used a large enough resistance to protect the device. His reasoning was he needed a low impedance because they were looking for wide bandwidth events. Meanwhile, the Air Force was running out of in-house discretionary money to fund this project, so the decision was made by "the powers that be" to write a report with lots of equations and fancy graphs that no one would read and shut the project down. Which they did.
About ten years later I finally got my own BEE degree, but I never again got to work with avalanche photo diodes, although I did get to work with plenty of other photo detectors... and lasers... and other spiffy electro-optical devices. Moral of this story? Probably none, but I would be very careful working with your avalanche photo diode. Without adequate current limiting, it is very easy to damage the device while it is under reverse bias by exposing it to ambient light. Star light is probably okay (except for our Sun), but I would be careful with a full moon in a clear sky. A pin-hole aperture with light reflecting off a spinning wire might be a good way to excite it with a very fast and narrow pulse of light. I would also consider using pulsed-DC reverse bias synchronized to the spinning wire for sensor excitation.
CommanderLake
Oct 2, 2012
227
I was hoping you might post Howard, my aspergers may affect communication but I have a vast imagination that allows me to visualise things like few people can.
Avalanche diodes are intriguing but they dont quite excite me the way a photon excites them knowing how much money I could so easily loose in experimenting with them.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Hi! I am aware of your fertile imagination as well as your Asperger's autism. One of my grandchildren "suffers" the same thing and we think perhaps one of his younger sisters does too. In both siblings it is "mild" and they both have "discovered" or invented other ways to communicate. It's a fascinatingly different way to view the world. Of course, considering quantum entanglement, just about any view of the world is valid now. But let's not go there in THIS thread.
Avalanche conduction, or impact ionization as it is often called, is a common phenomenon. It is the cause of lightning strokes and other electrical arcs occurring in gaseous media such as our atmosphere. It is also a common, although usually destructive, mechanism of a reverse-biased semiconductor junction above a certain threshold voltage. It is NOT related to the Zener effect, which is also a phenomenon related to reverse-biased semiconductor junctions.
Avalanche conduction occurs when an electrical field accelerates a charged particle, thereby adding kinetic energy to that particle. If the accelerated charged particle impacts (or comes reasonably close to) another particle it can transfer (by impact) part of the acquired kinetic energy to that particle, sometimes ionizing the impacted particle as well as other nearby particles. These newly ionized particles are then also accelerated by the electrical field and gain enough energy to repeat the process, resulting in multiplication of the charge carriers. The result is a runaway avalanche of conduction. How long this takes depends on, among other things, the mobility of the charge carriers in the electrical field, but it is usually very fast... nanoseconds rather than microseconds. In some devices the switching time is picoseconds.
You can observe (non-destructively) avalanche conduction in ordinary diodes by slowly applying and increasing a sufficient reverse voltage through a high-valued current-limiting resistor. Have a goodly supply of diodes on hand until you discover what value of current-limiting resistor will allow you to observe the avalanche effect without destroying the diode. Record the voltage where avalanche occurs and compare diodes. Most of all: have FUN!
Some bipolar junction transistors (BJTs) can be operated in the avalanche mode to provide increased switching speed (mainly), but AFAIK no one does this anymore. Same caveats apply. If you don't know what your are doing the transistors do not survive.
CommanderLake
Oct 2, 2012
227
I didn't realise how common avalanche conduction is, I have an old plasma globe that I've experimented with by taking the globe off and touching the bare wire coming out of the flyback transformer with a screwdriver.
Just out of interest I had a look at the electric field by putting an oscilloscope probe near the globe but not touching it and it runs at about 38.5KHz with a rounded triangular wave.
The only diodes I have spare are 1N4007 from an old Velleman kit, I wont be playing with that much DC voltage any time soon but I might add some cheap diodes to my next order from Digikey.
I tested one of my photo diodes up to 60v which is as high as my bench supply goes and it survived.
As for quantum entanglement, I have in fact done some research on that recently, check out this video: www.youtube.com/watch?v=nhBFQPiYt8k
Also the double slit experiment: www.youtube.com/watch?v=A9tKncAdlHQ
The thing I dont quite understand about the double slit experiment as explained in that video is when they use what I assume is a photon detector(still on topic) to detect individual photons going through the slits and the result they get is different in that there are just 2 stripes instead of many, I didn't think it would be possible to observe a photon without changing its state somehow or completely absorbing it, its like the photon had its memory of having gone through the slit(s) erased.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
I haven't performed the double-slit experiment with anything that could "spy" on what happens if there is something that records or detects a single photon exiting one of the two slits. However, "common sense" might say that if a photon is detected, then that's a photon that cannot experience "interference" from the other slit, I will have to look for details on how the "observed" slit directs its photons to the detector. My first choice would be a beam-splitter located after the slit, half the photons going to the photon detector and the other half going to the screen where interference occurs. I would instrument both light paths this way. Two photon detectors and two beam-splitters. Use a common red diode laser, the kind found in laser pointers, for illumination. I have seen these offered for sale for one dollar here in the States, paired with a "white" LED for general illumination, and packaged as a key-chain.
CommanderLake
Oct 2, 2012
227
Could it be something to do with quantum entanglement after the photon goes through the beam splitter?
