Pi filter for impedance matching
walid1
Jun 27, 2004
749
Hellow,
I build the following pi filter to match 100 ohm source to 1000 ohm load, I did the calculations based on RF Circuit Design Book
As u can see at the center freq fc = 30MHz & Q=15 I had 3.771dB, I was surprised by where this value? this is amplification!!!!
The second question is: If i want to match 1000 ohm source to 100 ohm load, Simply replace the capacitors, one must place the other, when i did so and simulate i had the following:
Look!! -9.8dB at the center freq.
can you please comment, how to match big source to small load without that bad attenuation
thanks alot
Kevin Weddle
Feb 23, 2004
1,620
A pi filter can be used to match loads? Most impedance matching that I've seen match the source and load impedance. Although depending on the application, pi filters can play a role in impedance matching.
walid1
Jun 27, 2004
749
Thank you KevinIV for reply
my question is why and how filter amplify signals??
Kevin Weddle
Feb 23, 2004
1,620
I'm surpised at the results. I know that mismatching impedances can cause standing waves, and it may depend on where you probe on the transmission line. But I think there would still be enough signal loss, and it would seem hard to get that good of a measurement to make a comparison.
audioguru2
Apr 6, 2004
12,026
A series LC circuit is a low impedance at resonance. The signal current is high. The voltage across its capacitor and the voltage across its inductor is higher than the input signal voltage.
indulis
Nov 21, 2005
488
This is a "second order" circuit. You took a bode plot over a frequency range. Things are going to change over frequency. Have you solved the differential equation for this circuit to find the poles and zeros? It's also what is called a "passive circuit"... so, unless you hit a resonant frequency (as AG pointed out) in your sweep, this thing can only attenuate.
