PIC assembly code EEPROM
W
wt
In PIC's such as the 16F84A, there is 64 bytes of EEPROM memory for data.
How can you set some of these memory with values in assembly code? I don't
want to be using the EEPROM's control registers and stuff, I want the hex
file to contain the data and load it onto the PIC directly.
Tim Daneliuk
wt said:
Stick this in your asm file somewhere (I like to do it at the end):
;;; EEPROM Contents
org 2100h
DE "This will end up in E2PROM"
