Pic programming problem
R.Lewis
Using the latest (downloaded) MPLAB I have a problem with the assembler in
that it assumes that all equates are for registers.
e.g. the equate
FRED equ 64h
gives an error message for a 12F629 'illegal memory location' (there is no
reg at 64h in the F629).
What is wrong here?
Anthony Fremont
e.g. the equate
FRED equ 64h
That's seems odd. You should be able to 'equ' any symbol to any 32bit
number. Tell us in what context you are using FRED. In other words
post the actual code.
When I try to do something like this:
FRED equ 3425h
movwf FRED
I get 'Invalid RAM location specified' and not 'illegal memory location'
Please post your actual code that defines FRED and where FRED is
referenced. Also make sure that your source file contains DOS CR/LF
pairs at the end of each source line. Otherwise MPLAB does strange
things.
Rene Tschaggelar
e.g. the equate
FRED equ 64h
What is wrong here?
Wasn't there a token to tell it that data comes ?
CSEG ? DSEG ? DBLOCK ? DATA ?
Rene
Al Borowski
e.g. the equate
FRED equ 64h
What is wrong here?
This is probably wrong, but try
fred equ h'64'
and see what happens.
Al
R.Lewis
FRED equ 3425h
movwf FRED
things.
It may well be that the message was as you stated (I am not in front of that
pc now) as I was working from memory.
The prog assembles and runs perfectly OK provided that I have no value
equates so I had to slog through the code changing all the code to the
literal numbers rather than their labels. There is no problem with anything
other than literals.
In every case the opcode using FRED (and several other similar equates) was
as (the radix is hex)
FRED EQU 64
JIM EQU 0A
MOVLW FRED ; or JIM
SUBWF etc ;
i.e FRED and JIM are only ever used as literals
but it will not assemble.
R.Lewis
Rene
No.
It is just simply of the form
<label> EQU <expression>
Anthony Fremont
FRED EQU 64
JIM EQU 0A
MOVLW FRED ; or JIM
SUBWF etc ;
I don't see any problem with what you posted. The only thing I can
suggest is that you join the piclist at www.piclist.com and ask your
question there. I'm currently using MPLAB 6.10.0.0 and it seems to have
no trouble.
Jan Panteltje
e.g. the equate
FRED equ 64h
What is wrong here?
MPLAB I think
I use gpasm in Linux...
and there it works without problems, you can equ any value
You SHOULD be able to equ bit values, else the assembler is of little use.
What does the doc say (I have mplab on the machine, but cannot reboot now in
windows with it, server is online).
It worked on an older version of mplab I have here, I once tried that.
Does it do same for an other processor, say 16F84?
JP
maxfoo
fred equ h'64'
Al
Also...
fred equ 0x64
or better yet use the cblock directive...
cblock 0x20
fred
Larry
Curly
Moe
endc
Remove "HeadFromButt", before replying by email.
R.Lewis
Jan Panteltje said:
MPLAB I think
JP
I have had no previous problem (with earlier MPLAB's)
I am not (necessarily) saying it is MPLAB's fault but I am stumped at this
moment.
(I have been playing with these things since before they were Microchip when
the support (in the the UK) from GE was attrocious)
Anthony Fremont
moment.
Perhaps you mean GI (General Instruments)? As I said earlier, make sure
that your source file has DOS style CR/LF's as record separators.
R.Lewis
Yes, of course, I do - when you get to my age one general is pretty much
like another
Charles R. Ott
My MPASM help file says:
Table: Radix Specifications Type Syntax Example
Decimal D'<digits>'
.'<digits>' D'100'
.'100'
Hexadecimal H'<hex_digits>'
0x<hex_digits> H'9f'
0x9f
Octal O'<octal_digits>' O'777'
Binary B'<binary_digits>' B'00111001'
ASCII A'<character>'
'<character>' A'C'
'C'
Randy Ott
