Programming PIC to sontrol 6x SERVOs
camerart
Aug 18, 2010
140
You have a delay in the handler. This means you really don't understand how it is supposed to work, so let me try to explain it.
Hi B,
When you say I have a delay, do you mean this: 'WaitUs timxh ?
The apostrophe is when it is commented out. I realised my mistake.
Thanks, I'll try again tomorrow.
C.
Ah, okay. Like I said, I was not familiar with the language you are using.
camerart
Aug 18, 2010
140
Hi B,
How does this look so far?
I can see that there are some mistakes,and some lines for testing, that need removing.
If you can look at the INTERRUPT LOOP, and see if it looks something like your ideas.
I have a waitms 14, which will be calculated later as a TMR0 delay.
Should there be OFF delays as well, or should it work with only ON/DELAY/OFF?
C.
  • 18LF4431 SERVO 250618 1100.txt
camerart
Aug 18, 2010
140
Hi B,
Thank you for your patience explaining how the TIMER works.
It is almost working, but needs Oshonsoft language skills to go farther.
Much appreciated,
Camerart
camerart
Aug 18, 2010
140
Update!
I'm concentrating on other things at the moment, so this is a summary.
I have now got the SERVO ouputs to work, using PPM (I think) with a timer interrupt.
camerart
Aug 18, 2010
140
14,317
camerart
Aug 18, 2010
140
Google is your friend:
"C" huh? What do you mean by this?
Hi H,
Thanks for your search, but neither of them is SPI. The first one is I2C and the second one requires the SPI wires as shown here:
Cheers, C for Camerart.
14,317
I'm sorry, an oversight on my part.
What is the reason you need SPI and can't use I²C or UART?
camerart
Aug 18, 2010
140
Hi H,
I chose SPI when I started this project a few years ago, so all of my peripherals use it.
Regarding the GPS UART:
The UART shares it's use with Radio control and needed a switch between the 2x, so if I can get SPI to work, it would solve this.
The UART alternative, is to use a software UART, which while it works, the problem is that it grabs the PIC process.
The SPI of the GPS is immensely difficult to do. If anyone knows how to do it let me know, but even if you search, beware there are rabbit holes that go nowhere.
C.
juliasmith
Nov 13, 2022
11
You can use picaxe as you are using PIC's for doing your project.But arduino would be much better than using PIC.
camerart
Aug 18, 2010
140
Did you look.,.?
Hi B and J,
No, my apologies.
I've been using PICs for a long time, so I didn't move to Arduino, when they got popular, as I had PIC CODE.
Instead of the Arduino libraries, that are simply used, I chose to write my own libraries, so I understood them
camerart
Aug 18, 2010
140
I received help from another forum, and added a 'shift register' to my PCB, this switches in a loop round all SERVO/MOTORs and sets an angle or speed for each one as it goes.
It's working fine.
camerart
Aug 18, 2010
140
It's working fine.
Hi N,
Thanks.
As #59, I used a shift register, to cycle through each SERVO/MOTOR, while leaving each one on for the 'set speed' time.
C.
