PIC16F628 L/C METER, LCD Display?
H
Hammy
I'm thinking of building this simple L/C meter.
http://www.marc.org.au/
I've never used an LCD with a PIC before, so for the display LCD what
should I be looking for? They are using a 16 x 2 LCD AMPIRE AC-162D
for the L/C meter.
AMPIRE Data sheet
http://home.exetel.com.au/marknac/PDFs/ampire-display-specs-AC162D.pdf
Would this be a suitable substitute?
LUMEX - LCM-S01602DTR/C - 16X2 CHAR LCD MODULE,TNREFLECTIVE
http://canada.newark.com/lumex/lcm-s01602dtr-c/16x2-char-lcd-module-tnreflective/dp/19J7663
Data sheet
Page two LCM-S01602DTR/C
http://www.lumex.com/pdf/LCM-S01602DTR+C-page2.pdf
Page one
http://www.lumex.com/pdf/LCM-S01602DTR+C-page1.pdf
What I'm trying to avoid is modifying the existing code which is on
the first web site. I'm looking for an inexpensive solution I could
put together quickly.The only thing I dont have is the display.
Raveninghorde
for the L/C meter.
AMPIRE Data sheet
Data sheet
Page one
The LCDs look interchangeable and I've not come across any with this
pin out that aren't.
Spehro Pefhany
Indeed, IME they all use the same controller chip set (Hitachi HD44780
+ HD44100, IIRC) or very close clones, so most should work.
OTOH, VFD and OLED displays that claim to be compatible often have
subtle differences in timing etc.
Also, it's not impossible in a 'hobby' project that the code is not
written to meet all the specs, but chances are it will work.
H
Hammy
I'll order a couple of them then.
Thanks for the replies Spehro Pefhany and Raveninghorde.
