PIC18 Serial Communications
Nlis12
Oct 10, 2017
7
Greetings,
I have a PIC18F67K90 chip that I am trying to configure for serial communication with a computer.
For this particular chip, pins (TX/RX) 4/5 and 31/32 are dedicated to serial communication. (USART)
These pins are already used for other things.
I was wondering if I could configure an unused TTL/Digital I/O pin to read in serial data to the USART or do I have to use the dedicated pins?
Any insight is appreciated.
Thanks in advance!
HellasTechn
Apr 14, 2013
1,579
Or re assign the pins if it is not to hard to alter the code accordingly ?
14,317
Afaik it is not possible to route the signals from other I/O pins to the internal U(S)ART. You are bound to use the dedicated pins if you want to use the HW-UART of the chip.
As @HellasTechn proposed/asked: re-route the external wiring such that the RxD and TxD pins are free for use with the UART, use other I/P pins for the signals that previously occupied the RxD and TxD pins.
'Bit banging' as propsed by @Minder can be used on any I/O pin but requires some effort in software and uses possibly valuable processor ressources at runtime.
