Pics: Hot Plate Soldering...On a Kitchen Stove
D from BC
Poorman hot plate soldering.. on my kitchen stove. :p
Some photo blurring added to pcb..
http://www.members.shaw.ca/chainsaw/SED/presoldering.jpg
428kB
http://www.members.shaw.ca/chainsaw/SED/postsoldering.jpg
423kB
wtf :(
I prefluxed the board with water soluble rework flux expired 2003.
Looks like the copper has a baked on residue??
I tried water. Then methyl alcohol. Zip.. MEK will probably kill the
pots.
Oh well...free conformal coating :p
But the soldering turned out great!
No shorts or opens found yet..
Comments/questions?
D from BC
gearhead
428kB
423kB
wtf :(
pots.
Comments/questions?
D from BC
I experimented placing a pc board on a metal screen over a halogen
light. That works, actually if you position the board very near the
light it can melt the solder in a matter of seconds.
With techniques like you and I are using, one ought to consider the
mechanical stresses on the parts resulting from uneven heating and
cooling. It might be a good idea to preheat the whole assembly. I'm
thinking maybe use a dimmer, heat the assembly at low power until the
whole thing is at 150 C or so, then turn the power up just long enough
to melt the solder, then off.
ChairmanOfTheBored
428kB
423kB
wtf :(
pots.
Comments/questions?
D from BC
One comment Do NOT dip the damned thing, float it, and then "peel" it
off the float at an angle to keep from forming icicles. Also, pre-heat
the assembly in a toaster oven or such before the dip, as the shock of
dipping a cold assembly is harmful to many of the parts, particularly
plastic encapsulated IC chips.
The tile is a nice addition.
D from BC
428kB
423kB
wtf :(
pots.
Comments/questions?
D from BC
Accepting free hot plate donations :)
D from BC
D from BC
The thermal rise and fall might be too sluggish.
After preheat, there's supposed to be a 10 second 'spike' to solder.
(Ref: Panasonic SMD app sheet soldering profile for chip resistors.)
On a stovetop, I could set one of the elements to preheat.
However, I'm not worried about thermal stress with test boards and
just skip all that.
By the way, I did try halogen soldering one time.
Used a 50W reflector halogen siliconed to a metal plate.
The plate did too much heat sinking :(
D from BC
D from BC
??? I didn't get that part..
Also, pre-heat
Yeah... the tile was all I could quickly find in the junk box.
I might try warming up the tile for a preheat. Then shuffle the tile
near the soldering plate.
I don't like all the shuffling though :(
Parts move.
D from BC
ChairmanOfTheBored
The way the corner of the board appeared to me, it looked as if you
dipped the whole board into the solder.
Parts move.
You should only use it for the thru hole parts, and do the SMT work by
hand.
D from BC
hand.
I coated the board with flux.
Applied solder paste on each pad.
Moved the board onto the tile.
Shuffled the board onto the hot plate for 20 seconds and then back
onto the tile.
I might improve the set up with a larger metal plate with a thermal
relief.
This will make a preheat area on the plate.
Topview of new plate for stovetop.
| |________+
| 245C | 150C |
^thermal resistance
D from BC
Paul Hovnanian P.E.
I've seen a few write ups on how to convert a toaster oven into a
soldering oven. The conversion usually involves adding a better temp.
sensor, programmable controller and triac control of the heating
elements. The homemade jobs can be set to follow a time vs temperature
curve optimum for soldering jobs.
D from BC
I tripped on that on that net..
Seems like too much work.
I like my metal plate on the stove top idea.
Total Cost: $1.50
Metal plate: 50 cents I think.
Oven Thermometer: 1 dollar
Set up time: <5 min.
Everybody has a stove! :)
D from BC
British Columbia
Canada.
