Piezo To Detect Sound
Rajinder
Jan 30, 2016
568
I am considering a project where i can use a piezo buzzer to detect sound rather than using a mic. I have seen different types of piezo buzzers, some with 2 wires and some with 3 wire. I think that the 3 wire has an additional feedback signal. Not sure.
Is this a possibility? I am trying to detect vibrations as if someone is trying to smash a glass or window i.e. security for the home.
Does anyone have any ideas on how this can be done. I was thinking piezo , with a pre-amplifier, peak detector and then comparator into a microcontroller.
Any help would be very much appreciated.
Best regards,
raj
Sunnysky
Jul 15, 2016
573
a buffered piezo mic = std. electret mic has the better EMI immunity. Use that instead.
AnalogKid
Jun 10, 2015
3,051
Also recommend an electret mic cartridge over a piezo disc.
And - if you talk with the people who make glass break detectors for home and commercial security systems, you lean stuff. For example, there is a large, very-low-frequency component to the sound of glass breaking, and that is the signature these detectors use so they don't false-trip on normal room sounds.
ak
Rajinder
Jan 30, 2016
568
ok thanks for your assistance. so an electret mic, amplifier and comparator or similar woul ddo the trick?
AnalogKid
Jun 10, 2015
3,051
That is the basic signal path to start. You probably will wind up adding filters or a rate limiter.
ak
Colin Mitchell
Aug 31, 2014
1,416
We use a piezo as a contact mic to hear right through glass with our wall bug transmitter. A bit tinny but as clear as a bell.
cl10Greg
Mar 20, 2014
25
Usually goes mic -> filter -> amplifier -> comparator. If you have the filter after the amplifier, you also amplify the noise
Herschel Peeler
Feb 21, 2016
401
ak
How low a low frequency component?
