Pinout needed: Telefunken 603 tranisistor
F
funky
From the 50's perhaps. A long black Ge with a dot near one leg. From
an old reel to reel tape recorder. The dot is the collector, center
leg is base and other is the emitter? Thank you for your time.
Arfa Daily
Guessing OC603. Package info sounds right, and it checks out right for
type, but a little later than 50's. Transistors didn't really start getting
into consumer stuff until the early sixties. I couldn't find any package
data in any of my old books, but the connections to blacked-glass
transistors with domed tops, was usually as you say ie E-B-C with the
collector marked with a red dot. Sometimes, there was also a slightly larger
space between the B-C legs, than the E-B legs. My data says that AC125 is
good enough equivalent
Arfa
Ross Herbert
I would agree with Arfa that the most likely part number you have is
an OC603, and your assumption is correct. C-B-E with the red dot
indicating the Collector. Its main use is as a low noise preamplifier
at low voltages and low power.
My old Mullard equivalent book shows the OC603 as equivalent to the
AC107.
Data for the Ge PNP AC107 is;
Vcb 15V
Vce 15V
Veb 5V
Ic 5mA
Ptot 83mW
By comparison the AC125 is more typical of an audio preamplifier or
driver transistor. ie,
Vcb 32V
Vce 32V
Veb 10V
Ic 200mA
Ptot 500mW
Ross H
Ross Herbert
AC107.
Vcb 15V
Vce 15V
Veb 5V
Ic 5mA
Ptot 83mW
PS. forgot the hfe (small signal gain) is 60 and f alpha cut-off freq
(common base cct) is 2MHz.
Vcb 32V
Vce 32V
Veb 10V
Ic 200mA
Ptot 500mW
hFE (large signal or DC current gain) is 100 and f1 (freq at which hfe
= 1) is 1.7MHz.
N
n cook
From 1973 manual
OD603 (confirmed OD not OC) by Telefunken
pnp Ge
Vcbo 40
Vceo 30
Ic max 10mA
Ptot 30mW
Icbo at Vcbo 0.025 uA
Reinhard Zwirner
n said:
From 1973 manual
O_D_ 603? Are you really sure? That's a Ge pnp transistor for
AF power stages! From 1969 manual:
abs. max. ratings ________
-Vcbo 40 V I I metal case
-Vceo 30 V __I_______I__
-Vebo 10 V I_____________ICollector connected to
case
-Ic 3 A |||
Ptot 6 W @ tcase < 45°C ||| C: blank wire
||| B: yellow insulation
||| E: green insulation
O_C_ 603 Ge pnp transistor for low noise input-stages.
-Vcbo 22 V / \
-Vceo 12 V I I case: black painted glass
-Vebo 10 V I I
-Ic 50 mA I I
Ptot 50 mW @ tamb = 45°C I___I<- colour dot
EBC
HTH
Reinhard
N
n cook
case
-Ic 3 A |||
||| E: green insulation
-Vcbo 22 V / \
-Vebo 10 V I I
-Ic 50 mA I I
EBC
HTH
Reinhard
Yes curious, the 1973 UK Semicon data book mentions the data as I
transcribed along with manufacturer being Telefunken, also mentions a
variant OD603/50.
But a German 1987 ECO (Electronic+Acoustic GmbH) book mentions
the one you refer to along with variant OD603, but no mention of Telefunken,
completely different characteristics.
Crossposted to de.sci.electronics
F
funky
variant OD603/50.
Thanks, everyone.
