wayigo8873
- Jan 9, 2026
- 2
- Joined
- Jan 9, 2026
- Messages
- 2
Hello everyone,
I’m currently working on a hardware salvage project and I’ve hit a wall regarding some proprietary power connectors. I figured this would be the best place to ask since I usually just lurk here for the schematic breakdowns.
I recently rescued an HP Smart Array P411 SAS-SATA controller from an e-waste pile. I’m trying to use it for a home lab setup, but the card is missing the "Flash Backed Write Cache" (FBWC) supercapacitor pack. Without that power source, the card disables the write cache, which absolutely kills the throughput performance. I really hate seeing perfectly good silicon go to the landfill just because of a missing battery, so I’m attempting to "MacGyver" a solution.
My specific technical question revolves around the voltage regulation on the daughterboard. There is a small proprietary header connecting the cache module to the capacitor pack. I want to wire in a generic supercap bank or an external DC source, but I can't find a datasheet for the pinout. I’ve probed the pins with my multimeter while the system is live, but the readings are fluctuating, likely because the controller is polling for a "battery present" signal.
I remember spending a whole week once trying to bypass a Lenovo fan whitelist by flashing a custom BIOS, so I know these proprietary checks can be a massive headache if you don't get the handshake right.
Has anyone here ever reverse-engineered the power circuit on these older Smart Array cards? I’m curious if there is a specific resistance value or logic high/low signal on a sense pin that tells the controller the "battery" is healthy, or if I simply need to supply a clean 5.4V to the main rail?
Thanks in advance for any insights!
