plasma Panasonic ''P-Board'' ETXMM655MEH , Trying to investigate
Jeffpepin
Nov 15, 2012
13
he !
i have a panasonic viera ( TH-50PX75U) dead since 2 month , This is for sure a power supply faillure because i have perfectly analysed the circumstances of the death ,
the tv sudend shut down , 10 blink Sos ( standby led) =no power '' all output voltages'' ,
Un/repluged it , hear the first relay cliked on , but it goes off ,ckik on immiadely then clik off .
Example :
ON ( 1sec)OFF(1/2sec)ON(1/4sec)OFF(1/8Sec)on(1/16Sec)Off ..... no more suffisent voltage to drive a relay.
After that , no more signs of life , no led , i have tested all troubleshoot guide and all results refer me at P-Board
ETXMM655MEH ( live circuit)
i need help ,Fuses are Ok , thermals resistor on transfo are ok ,no traces of burn, what next ? mosfet? , im just not sure where begin ,
For sure , it have +/- 30 000 other persons in this situation . if it have succes .. not just me will be happy to rescue ther tv
the schematic are here TH-50PX75U-Service-Manual
Jeffpepin
Nov 15, 2012
13
update i check all ic on the board ( mosfet rectifier .. ) im here :
test in diode mode with fluke 77 III multimeter
q352= 2sk2510
Q351= 2sk2510
SWITCHING N-CHANNEL POWER MOS FET
first one
With - on B return an infinite resistance on C. and .476 on E.
if i put + on C then E ,E will be .000 then slowy up at .476
With + on B REturn Infinite Both C AnD E
Second
With - on B return an infinite resistance on C. and .456 on E.
if i put + on C then E ,E will be .000 then slowy up at .456
D353 = Yg805c06
D351 =Yg805c06
SCHOTTKY BARRIER DIODE (60V / 20A TO-22OF15) - Fuji Electric
First one ,
With - on B return .130 on C. and .131 on E.
Infinite Between C and E Both side
Second ,
With - on B return .125 on C. and .126 on E.
Infinite Between C and E Both side too
D403 : Yg901C3
LOW LOSS SUPER HIGH SPEED DIODE - Fuji Electric
With - on B return .362 on C. and .362 on E.
Q401 : 2sk3607
N-CHANNEL SILICON POWER MOSFET - Fuji Electric
With - on B return infinite on C. and .498 on E.
This one look Strange because any side i test it ill get infinite between base and collector ?? .
if anywone can confirms if my reading seem to be good
