Hello!
To begin with, a little background: I am absolutely new in electronic and anything related to it, but recently rewired old speakers I found in my fathers attic, really liked the process (probably found a new hobby) and decided to make my own sub-woofer box as my first project. Bought a speaker, surfed internet a bit and find box plans, but decided to modify it a bit and add led lightening. Everything went pretty well, but now I encountered few questions and don't seem to find an answer on web, everything is confusing or not exactly I am looking for. Please give me some advice.
1) I connected led strip (4 segments x3 leds) to woofer and tested it, but it seem to light up only when volume is turned very loud, I would like it to shine in all volume range. Is any way to amplify signal to led strip?
2) I did not think through how I am going to connect woofer to my amplifier. Can you suggest clever way to do it?
3) In the test run (directly connected woofer instead of one speaker) woofer seemed way more quieter than I expected. Is there some way to make it play louder or it is because my amplifier and woofer limitations?
My amplifier Marantz PM583
Power output: 40 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 50kHz
Total harmonic distortion: 0.05%
Damping factor: 50
Input sensitivity: 4.5mV (MM), 400mV (line)
Signal to noise ratio: 75dB (MM), 90dB (line)
Channel separation: 60dB (line)
Woofer I bought Blow A-200
8'' Woofer
Max. Input power: 300W
Impedance: 8 Ohm
Frequency Response: 42Hz-6KHz
Sensitivity: 91dB/1w/1m
Magnet weight: 30 OZ
Aliuminium Voice Coil: 1.5''
I am adding few diagrams of my project:
My box plans
Instruction how to connect woofer I found (won't it burn my amplifier?)
I found led wiring diagram, it uses battery, would it make led shine during lover volumes? (diagram source http://www.instructables.com/id/Music-LED-Light-Box/step6/Building-the-circuit/)
How I connected leds and woofer
My working speakers connection diagram (maybe there are some clever way to connect woofer inside it?)
My amplifier back
Any help appreciated. Thank You in advance, and sorry for my (probably) dumb questions.
Damping factor: 50
8'' Woofer
Impedance: 8 Ohm
My box plans
My amplifier back
