please help me about my ultrasonic project!please
E.persia
hi everybody
excuse me Ihave a project about ultrasonic for measurment of distance
beetween two cars!
its not for avoidance of hit!it for reducing the speed to keep the
standard distance between two car
somy need is about 30 or 40 meters
its very long distance but its two neccessary for me
how can I do it
I read somthing about horn but its ....
you know its in a car!
what a horn can be our what a car????
accept my special thanks for your helps
Sjouke Burry
E.persia said:
hi everybody
beetween two cars!
how can I do it
We did this by useing an Israely IR laser with 10 cm reolution, and a serial
RS232 output.
We implemented a nice car following experiment with that.
(and no, I am not allowed to tell more about it :) :) )
BobG
Put a red laser on a stepper motor so it will rotate left and right.
Put this near the right headlight. Put a receiver near the left
headlight. Park the car with the laser X feet behind another car. Turn
on the laser, step the laser to the left until the reflection hits the
receiver. The number steps gives an angle, and the distance between
the laser and receiver is known. Should be able to calc distance X.
E.persia
sorry may be it's the second choice but my final project is about
ultrasonic amplifying to 50 meter!
Chris
hi everybody
beetween two cars!
how can I do it
Hi, Erfan. The basic principle of ultrasonics is sending out a brief
sound, then measuring the time until first echo. Using some quick
math (sound travels about 150 microseconds per inch), you can
determine the distance of the object that caused the echo.
Simple, and you probably know this. But there's another basic
physical fact -- the inverse square law also applies to acoustics.
That means you're going to need an awfully loud ultrasonic chirp (more
like the chirp of the largest pterodactyl that ever lived) to get a
reasonable echo at 80 meters total. Hence the horn, I guess.
In additioon, your sound is going to have to be filtered from the
noise of air rushing past the transducer (both cars are moving at a
reasonable speed).
I'd guess the best advice someone could give you would be to focus on
another method of determining distance.
Good luck
Chris
BobG
Does it HAVE to be ultrasonic? Those 3.5" tweeters can take about 25V
RMS and probably have peak acoustic output at about 3.5KHz... but if
you just beeped it for 10ms every 100ms it might not be too annoying.
At least if you can hear it, you can test it with a regular microphone.
