Please Help! Need to find out how to fix my portable charger!
jeremyrodas
Nov 15, 2011
6
I recently bought this Sanyo enloop mobile booster at a yard sale. It's missing a button and I'm trying to figure what kind of button it requires. Because the only way to actually charge it is by pressing the button. But all I see is a white little piece (not the button) and I try clicking it with something and no click or an response. It charges fine, when I connect it with a charger, batter does a normal charge and lights work, it's just the button that won't respond.
Please help:( :confused:
14,487
hi jeremy,
welcome :)
sorry the pic is just too small and blurry to really make out anything meaningful
try a little larger and much clearer :)
cheers
davelectronic
Dec 13, 2010
1,087
Hi there jeremyrodas.
I really find it hard to view the images, i am not sure, but it might be a momentary tactile type switch, but as said already the images are to blurred and far off, do you have macro on your camera for close ups.
If you have posted a second lot of images there not showing.
Dave.D
jeremyrodas
Nov 15, 2011
6
That's the best I can do):
Im using my iPhone so it's the best shot I can get):
davelectronic
Dec 13, 2010
1,087
Hi again.
i am still not seeing any other images, your phone should do the job, but the upload seems to have failed.
No images.
Dave.D
davelectronic
Dec 13, 2010
1,087
Hi again jeremyrodas.
Yes thats defiantly a momentary tactile switch with the button top missing, thats my humble judgement, it was or is a reset switch, as you said its charging, but it could be a charge activation switch, i am not sure which, can you press the very center with a none metallic implement tooth pic etc, if it wont push then the depress part of the switch is missing, then you need to take measurements of the footprint and solder a new one in place of the broken one.
Dave.D :)
davelectronic
Dec 13, 2010
1,087
There are members on the forum from all over the world, and i believe a fare few members in the USA so you should get components easy from where you are, i cant remember there names, the electronic stores that is, but there out there, other members from the US should be able to put you in the right direction on a store near you.
Dave.
